burying wire with subsoiler advice
/ burying wire with subsoiler advice #21
hey guys, thanks so much for taking the time to give me such useful detailed advice. the more i read, i think this might be one of those projects left to the pros, or at least get a certified electrician, to come out and look at the job, and tell me what would be better for this application. thanks again so much
I have plowed in lots of wire, from 12 gauge to 2 gauge. I always pull it through the ground like a rope. You will be surprised how little resistance it has. You can usually move it by hand when you're done. It creates its own tunnel through the dirt.
I have also plowed lots of PVC pipe, from 3/4" to 2 inch.
You will have trouble going 18 inches deep with 22 hp. You will have to make several dry passes first. You might also find that your 3ph doesn't have enough range to raise it clear of the ground.
I use 80 hp to make it in one pass. Good luck!
/ burying wire with subsoiler advice #22
Gabby
How do you attach the PVC pipe to your plow and do you use glued pipe in 20' lengths?
/ burying wire with subsoiler advice #23
jsborn, but if you plow around the stump where is the fun in that?
And mind telling how you know about the bumble bee's speed? No need, wasp are also faster. That is why I keep spray on my excavator and tractor if bush hogging. :)
/ burying wire with subsoiler advice #24
Good question Jsborn...I was also going to ask that, also. I have not tried pulling the PVC, just trenching and doing it piece by piece. What say you, Gabby?
/ burying wire with subsoiler advice #25
Also... I can see where the 20' PVC with the bell ends, so you connect them without couplings, would be a "slicker" pull, IF you pull with the straight end of the pipe. That way the bell end gives a tapered coupling area that wouldn't snag on a root or rock as you pull. But, have you done this with separate couplings, which would have a square shoulder that could snag on something in the ground? Also, how long do you let the glue dry before you continue to pull?
Thanks, jp
/ burying wire with subsoiler advice #26
I couldn't find my code book but if the foggy old brain works you need 12 gauge minimum for 300" and 15 amps, 10g would be better depending on total amp load plus current drop for the distance.
You might consider using 12/3 with ground, that will give you 2 separate circuits in one wire and pull.
I'm sure that theres a master electrician out there that will give us the correct info/specs.
As far as pulling the subsoiler 18" dep with 22hp, its doable ,depends on 2 things; traction and soil type. I've pulled my CK 20 HST 12-18" deep in one pass in sandy loam. In heavy clay Ive had to make 2 or 3 passes to get full 18". Of course roots and rocks don't count.
Have fun. Joe
I am new to this site, and have really enjoyed reading all the opinions and knowledge on this website!
Joe48,
You said that you have pulled up to 18" deep with a subsoiler. I would like to pull some flexible 3/4" pipe that deep to supply a "garden shed" that I am building for the wife.
I am a newbie to tractors and their implements. Does it depend on the subsoiler as to the depth it will "cut?" Or, are all subsoilers not created equally?
Thanks guys!
/ burying wire with subsoiler advice #27
I have a TC 29 and it will not pull a wire at 18". That takes alot of HP and traction.
As for the 300 foot run. Pull #2 wire and wire it for 240 volts. set a sub box at horse barn . You will be able to run more circuits and voltage loss will not be as crucial.
/ burying wire with subsoiler advice #28
I never direct bury wire any more.
Years ago when I build my first house. I hand trenched 3' deep several hundred feet to my well, installed 3 conductor #10 direct bury cable, and covered every thing up.
Several months later the pump quit working.... One of the wires, just one, either had a manufacturing defect and broke, or some critter chewed into it.
I had to redig everything, since then I have been using pipe.
/ burying wire with subsoiler advice #29
I understand the debate between using conduit and direct burial and that is fine ,my question is how do you attach the conduit to your subsoiler and pull it with out filling it with dirt ? I know you could use tape and drill a hole in the pipe and tape it closed but there seems to be better ways? Also Gabby can you expound on how you pull PVC conduit ? do you use 20 ft sticks glued together and if so how long can you pull without putting in a splice box? Do you have problems when you try to turn a curve?
Tks
/ burying wire with subsoiler advice #30
Glue it up like a long rope and plow away. So easy to do you can't believe we used to trench and then backfill and watch it settle and need filling again and again.
/ burying wire with subsoiler advice #31
Tks
Make a pulling head out of a PVC cap with a hole drilled in it. Put an eye bolt through the hole, add a washer and a nut inside the cap and you're ready to pull. Glue it to the pipe and plow away, just cut it off about 2 feet long when you're done so you can re-use the pulling head section.
I have pulled 900 continuous feet of 1-inch PVC.
Curves aren't a problem, just curve away.
/ burying wire with subsoiler advice #32
I made a dry run first with the subsoiler. Then I attach pvc to subsoiler ( however you do this is up to you. Tape end of PVC to prevent dirt from entering PVC. Have a helper to"help" PVC . Lay out PVC with staring end at beginning of trench. Pull it in . No problem, just like pulling in a piece of UF wire. I agree to use PVC. If it needs replaced, it can be easily done .
/ burying wire with subsoiler advice #33
You guys are lucky. My inspector would never approve line voltage wire at only 18".
/ burying wire with subsoiler advice #34
This is the wacky gadget i built to pull in my phone line . Telstra would not do the job because of erosion problems with my sandy soil . So i said i would do it . I borrowed the Poly Pipe ripper when i bought the roll of pipe pictured , tack welded it to the bottom of the bucket and put the roll of wire between the lift arms and used a piece of pipe for the axle . The Telecom guy was skeptical and said he would walk beside me to see how i was going . He went 20' and said i was doing a better job than they could :D . The jib on the back and the old winch on the bucket have nothing to do with the ripper . They are what i used to lift the poles for my house .
/ burying wire with subsoiler advice #35
I wish I could see a video of this in action. You guys describe it and yet I guess I'm one of those guys that has to see it to finally understand it.
I suppose I could take a piece of rope and trying burying it just for learning how to do this. I'd hate to wreck a piece of wiring at today's prices.
/ burying wire with subsoiler advice #36
What does work well is the way i got my power wire up to the house . I first pulled in a 100' of Poly Pipe and then blew a parachute up the line with a string attached . I then pulled the power wire up the pipe . I only used Black pipe which is probably dangerous , someone later might cut it thinking it's water . If you can buy Orange pipe it would be better .
/ burying wire with subsoiler advice #37
Joe48,
Thanks guys!
Yes there is a difference. There could be a difference between manufacturers, the size of compact (super compact vs compact) tractor it's designed for and probably most noteably, whether the attachment is a middle-buster subsoiler combo or strictly a subsoiler (sometimes called a chisel plow). I'd suggest you look at a few and select the one with the longest beam below the 3-pt lower-link attachement points.
/ burying wire with subsoiler advice #38
You said you were going to pass and let the pros do it. This is one area where you can save money and do it yourself. Electricians charge a lot do do burial work.
/ burying wire with subsoiler advice #39
hi,
Gustav forced me to bury the cable TV line. This was put together with scrap odds and ends. The cutting knife was a BushHog blade found on the roadside and sharpend all the way up. That is 1" Galv Pipe, the bottom bend was enough. Check out the high tech anti-chaffing feed guide at the top of pipe (qt plastic oil spout).
It worked great, burrying the super duty coax the cable company left, the depth was 18" +/- . It left minimal disturbance to grass, a bigger tractor would have been a plus.
Good Luck
Rhett
/ burying wire with subsoiler advice #40
For those of you that are skeptical, make several passes and lower the subsoiler each time until you are ripping at the depth you want to bury the PVC, or direct burial wire, but you must consider the fact that if pulling direct burial wire, that you still may snag the wire on something, so therefore, I would recommend puling the wire and PVC. I would also put some foam in both ends of the line to keep out water.
I would dig a hole at the starting spot, and a 6 ft ramp leading down to the bottom of the hole, and when you start to pull, have someone hold the PVC pipe down in the hole.
Subsoiler adapter.
I welded a chain link to the subsoiler, and then attaching a small length of chain, welded to a 3/4 in galv pipe cap, and screwed the PVC pipe into this for water pipe, and for wire and PVC, add the correct size coupler and bring the wire out of a side hole and tape good. If you are going to be doing this often, I would make pipe adapters to fit the pipe you are pulling. I made several bullet head or mole adapters larger than the pipe, and they expand the dirt and make pulling the pipe easier.
Happy pulling.
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
2007 Ford E350 (A55973)
2007 Ford E350...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2014 PETERBILT 388 CAR HAULER (A59904)
2014 PETERBILT 388...
EZ loader trailer (A56857)
EZ loader trailer...
