Weight is bad
/ Weight is bad #1
MessickFarmEqu
Super Member
Lancaster County, PA
I just got out of a 4 hour class on weight and ballast. Thought I'd throw it up here for you all to chew on. It was run by New Holland, who is a middle of the road company when it comes to their own products weight.
The basic principle of this class was to dispel the old farmer myth that more weight is better. Todays modern tractors are built in a way that weight no longer is equal to durability. More often its the opposite. The basic consensus is that beyond a reasonable amount, weight is bad as it does nothing but burn fuel, wear tires, increase compaction, easier to get stuck, and make the tractor more sluggish.
Todays machines should be ballasted, not just heavy. For most of the work you see compacts doing a 35/65 F/R split is about right. Put too much on the rear and your front tires are not doing any work, have too much in the front and you start to fight the lead of the FWD. Neither are good. The work your doing changes this. Obviously loader work moves a lot of weight front, 3pt work pulls to the rear as the front end lifts.
The trend is towards doing work with as little weight as possible. They had a really interesting series of videos of tractors pulling cultivators and the difference that ballasting would make over even a short span. The most efficient machine out of the group happened to be the lightest machine without the duel tires and front weights we're used to seeing. Taking the same tractor and putting 2000lbs in the wrong place could skew things nearly 20%.
One thing I learned is that the liquid ballast that we often use in compacts is a huge detriment to traction. Changing a machine to iron weights improves ride and traction to the point that it can make a 10% difference in productivity. Field tractors are typically setup for 100-130lbs per PTO HP. Ideally you would want to be as light as your application will allow while being properly ballasted.
The first objection here is that you need weight for traction, however thats easy to overcome by lowering tire pressure providing that your machine is not setup go gosh darn heavy that the side walls can't take it. Modern tire designs and drive systems have made raw mass unneeded for most applications. They're putting 300Hp field tractors out at 5-6 psi. We spend good money for radial tires so they'll do this, but we don't put them to work. A bias ply is much cheaper if your not interested in running low PSI.
About the only application where you really want weight is when your working on hills (providing its all down low) and when you need to stop something like a bale wagon, manure tanker, etc.
thoughts?
/ Weight is bad #2
I just got out of a 4 hour class on weight and ballast. Thought I'd throw it up here for you all to chew on...
Very interesting post with great information. Thanks for sharing. Do you have any of the videos or presentation slides to post? What was the name of this class (I'd like to ask my NH dealer about it)?
The basic principle of this class was to dispel the old farmer myth that more weight is better...
In the examples you sited for front / rear ratios and rotor tiller pulling setups was that using 2wd or 4wd? Did they mention how 2wd vs 4wd mode affects weight setups?
Yikes, you probably just made a lot of people mad, or at least uncomfortable with that statement. Filling tires seems to be a big "gotta have" for a lot of people. Once you put weight in your tires you are stuck with the extra weight. If you choose iron weights and / or a ballast box you have a lot of flexibility in your weighting and you can get rid of the extra weight when you don't want it.
/ Weight is bad #3
I would think it all boils down to ground pressure and a given draw bar load.
maintain 4-5 psi, and keep adding tire/ground contact until you run out of HP.
(assuming you not pulling 60hp of load on a 300hp machine)
/ Weight is bad #4
For field machines that is a pretty good bet, but what about our dinky little machines? What are the weight ratios we have? Also, why are they comparing PTO hp when drawbar hp would be the better gage to weight?
Then I have to ask myself, what is the expected differential gain for a steel wheel weight (that is less overall poundage) than the fill in real world benefit compared to the cost difference ?
Answer -> dunno.
jb
/ Weight is bad #5
For what I saw when Case introduced this stuff about ten plus years ago you could be about 10% lighter without the fluid to give the same results when pulling a load.
Buy cast, you buy it once!
There are tractors built that are effectively to heavy to properly balance without over weighting.
/ Weight is bad #6
Neil, that seminar sounds like it is directed more towards ag tractors than the compacts most of us have. The ballast in my rear tires is to keep the wheels on the ground instead of off the ground where they provide no traction or braking whatsoever. I resisted filling my tires until I got a rock bucket when I had to get my tires filled. I cannot remember one "pucker moment" since filling my rear tires, but I sure had many before filling them; although, most of those were moving downhill with a FEL load. I rarely had problems on level ground.
For draft work, all you say seems to make sense, but for the kind of work most of us do with our compacts, loading the rear tires adds stability. At least that's my "real world" experience. Although it doesn't apply to me, I'd like to see how ballast and weight applies when plowing snow. Would lighter work just as well as heavier?
/ Weight is bad #7
I normally wouldn't try to contradict anyone who's business is what the discussion is about; and I don't disagree with the premise at all...EXCEPT...when you have an 1500-1800 FEL on the front of a 6300lb base tractor (50+ PTO HP), you best better have about 1200-1400 lbs of "ballast" in your rear tires...When I bought my Mahindra 6000 I had the rears ballasted before it was delivered...really glad I did....By the way, with an FEL, there aint no way you can get all your HP to the ground without that 1300lbs in the ***** end...less compaction doesn't mean much if you can't pull the equipment...just my $.02. BobG in VA
/ Weight is bad #8
/ Weight is bad #9
I can see how too much ballast reduces the effectiveness of FWD. I experience this on my little tractor with loaded tires and the backhoe hanging out back. Front end gets real light. But I'm not going to run out there and drain the fluid out either. Stability is just too important.:D
I don't see their position as applying across the board for all sizes and configurations. From what I have seen a light compact benefits greatly from added weight as long as it's properly distributed.
/ Weight is bad #10
Thanks for that post, Neil. Very informative. I think we each should weigh it in light of our own experience and needs, however.
I know, filled rears are a "gotta-have" on my tractors, yet the old Ford 4000 still isn't filled. Of the tractors I work with (the JD is down), the 4000 is the only one that makes me nervous on hills....sometimes very nervous on not much of a hill. Would iron be better?? Dunno....but it certainly wouldn't be as low down as the fluid.
Most of the larger machines I've operated for the neighbor have been heavily front ballasted and equipped with duals. They needed all the help they could get. On a steep sidehill, they often still had trouble holding a merger or a MoCo on its windrow. When it got really steep having two big ones on the downhill side was comforting as well. I have noticed, however, that fuel consumption seems quite high on all of those tractors.
Also old-school tractors with lots of HP and grabby clutches need the front ballast to keep the nose down. Was operating an old JD6300 recently that would lift the fronts off the ground with the least provocation. Scared me bad a few times. More predictable clutches eliminate the need.
Bob
/ Weight is bad #11
My land is pretty much nothing but hills, and some pretty scary ones at that. I had the tires filled (per my 1999 Hew Holland manual) and it has helped. Purely from a mass and inertia standpoint it would appear to be better than cast iron, as the CG of the liquid is going to be slightly below the axle, whereas with weights it's right on the axle line. It'd depend on how your weights are mounted as to which (liquid or cast iron) is further outboard.
I likd the OP and it was great information. I'd love to haul around as little weight as possible, with my little 18 hp I don't have a lot to spare. But I really have no way to determine my F/R weight ratio. So I reckon I'll continue to go by "feel" and hope my pucker factor is calibrated properly.
/ Weight is bad #12
I was moving a lot of stuff with my 404 this weekend across soft ground and was wishing the rear tires weren't filled or maybe that they were R4's and not R1's :D. I had to go way out of my way on repeated trips to make sure I wasn't leaving ruts.
2 hours later I was moving some rock and needed all the traction I could get. There's no way I could have done it as easily without the weight of the filled tires. Sure, I could have done the same thing with iron weight but no way would I have removed it for the first job then re-installed it for the later work. Fighting 800 lbs of weight off and on doesn't seem like an enjoyable way to spend time and not every efficient if you have a bunch of small jobs to do.
There's cost and convenience with filled tires even if it might not be a perfect solution. How much does 800 lbs of CC cost vs iron and how much wider would the tractor be with the iron bolted to the wheels?
If nothing else it's proof there's no optimum that covers every job.
/ Weight is bad #13
Good info.. really missleading title to the message though.
Weight in and of itself is not bad. Improper weight is detrimental. Not enough ballast is bad.. too much is bad.. IE.. the extremes.
soundguy
thoughts?
/ Weight is bad #14
I think that the information presented is probably 100% correct.... for the ag tractors doing field work. That's what the presentation was for. There is probably still some information that is valuable to us utility users in there too. But, the benefit cost of cast iron weight vs tire fill is small for my uses -- so I don't worry about it.
It would be interesting to learn about the weight and balance for utility tractors and FEL tractors.
jb
/ Weight is bad #15
This was a very good informative post. It's funny how we all pick apart all the good stuff we read here 'till we make it sound like (insert your own words here). I think what the OP wrote, or the info from NH is info we can take and use to help us load our tractors to fit our needs better.
I've got a BX 24 that I want to keep as light as possible for mowing but live on a hill so would like to load the tires, but in the winter I wouldn't want the traction loss of loaded tires even though I live on a hill. Basically what I'd like is a knob that makes the tires loaded when on hills and light when mowing or plowing snow:D. I'll just use my gravitational tipover sensor mounted to my rear and not load the tires.
By using this information and applying it to our needs we can become more efficient using our tractors. In theory this information applies to both, AG and SCUTS. You just have to use common sense and good judgement to add weight to your's so that it best suits your needs. Thanks MessickFarmEqu for the post.
/ Weight is bad
Yes it is. Loader work requires rear ballast... but not raw weight.
Its offered internaly for salespeople. They say the principles and calculators for this are headed to the website.
Yea myself included. We use liquid religiously. They also say that it adds to the rolling resistance of the tire, where iron does not. I can't argue, beyond cost it seems iron is clearly better.
Good info.. really misleading title to the message though.
thats intentinal... gotta spark some interest!
Someone asked about balance for 2WD. That goes about 70/30 from what I remeber.
There are going to be applications that require differing setups. If you own a ballast box and some cast weights you should be able to setup your compact for whatever your doing. The point to drive home is that a few minutes of prep before you go out to work for the day can be more than made up though added productivity.
/ Weight is bad #17
Well, they make the next best thing to the "knob" that you wish for. It is called a ballast box. With my NH deluxe 3pt I can get a ballast box on / off in 5 minutes. The ballast box is a lot cheaper than filled tires and you get to control exactly how much extra weight you want. My ballast box when fully loaded comes in at about 2000lbs. Good thing is I can take it off when I don't need or want it. You can have your cake and eat it too (so to speak). For people with a "standard" fixed 3pt I can see where getting the ballast box on and off might be more of a pain though.
/ Weight is bad #18
I think the liquid ballast observations are the ones that are most surprising. The others intuitively make sense to me. It seems like the penalty of rolling resistance in utility and CU tractors is relatively inconsequencial. Fuel consumption is unlikey to be a big issue for those of use in the 50hp and under group or at least us weekend warriors. I'm not sure how restricted sidewall flex impacts typical CUT use. I'm guessing but I'd suspect that most CUTs do not come with or ever get radials anyway.
Ballast boxes have no appeal for me. They just tie up a spot for an implement. I keep a BB on the back and find it necessary to have something back there when doing loader work. But as often as not, I'll have a use for the BB during most loader tasks and a ballast box back there ruins that. But that's just me.
I'd love to have cast iron wheel weights. I don't remember how much they cost but I do remember that I almost had a stroke when I heard. I also think if I had them or could afford them.....I'd keep the liquid ballst too.
/ Weight is bad #19
Below is an article I found on tractor weight. It reads pretty good. All I know is from real world experience. The only tractor I really hear farmers complain about is the Kubota. I've seen Kubota's that seem to be too light for some simple front end loader work in my opinion. I've know a couple guys who have Kubota's that like them, but when asked what is their biggest complaint, it seems to be wheel slippage and too light for the bigger jobs. I know my tractor is about 1000lbs heavier than the comparable Kubota and there have been a few loader applications that I would have liked to have more weight.
Everyone says you can always add weight, but how much can you really add? Anyone have an idea?
G1235 Tractor Tire and Ballast Management, MU Extension
/ Weight is bad #20
I think it is a reasonable generalization that Kubotas are lighter tractors, especially when compared with a brand like Mahindra for instance.
But, I have found this to be more model dependant than brand dependant. I was recently comparing some utility and Ag sized Kubotas to their JD counterparts and several of the Kubotas were heavier than the comparable JD.
For many CUT users, lightness can be an advantage. A lot of these smaller machines are used on lawns and for landscaping. Also, in my case, I have a 45 hp Kubota that is quite light in my opinion (even though it is about the same as its JD counterpart the 990). I have the rears filled but no other wieght. I figure with the rears filled, loader on, BB on, it weighs around 5000 pounds. A trailer might weigh another 2000. That's pushing the 7500 pound limit of my '03 F150 SuperCrew with towing package. If this tractor weighed another 500-800 pounds, it could exceed the recommended towing weight of my truck. I wouldn't want that.
And I would agree that I can get the wheels to spin, but I'm not sure at what cost. None I think. It pulls whatever I've hooked to it. Carries its rated loader weight, etc etc. If I was plowing hundreds of acres and tire slippage cost me in fuel, it might be an issue. Otherwise, it has not restricted my activites and don't see it being an issue with most CUT users.
As for how much, I don't know but I think it is reasonable to assume that you can fill the rears, add the recommended cast iron wheel weights, as much weight as the 3 pt is rated at and as much weight as the front wieght rack is designed to hold plus a laoder full. Now, I can't see any reason for all that and as the OP mentions, where you put it and why is probably more important than your total amount.
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63688)
2019 Cadillac XTS...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
UNUSED AGT 12EX-ATA MINI EXCAVATOR (A64281)
UNUSED AGT...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
UNUSED WOLVERINE (A64281)
UNUSED WOLVERINE...
1985 23ft Mako Center Console Boat with 2011 28ft HMDE Trailer (A61574)
1985 23ft Mako...
