Weight is bad
/ Weight is bad #41
Exactly. We add & remove weight as needed, and for other jobs, no weight at all. The tires are not loaded and NEVER will be.
I think a lot of people are missing the point.
The OP was trying to say that excessive weight is a bad thing. The hard part is trying to figure out the "right" amount of weight for each job. I always leave the front weights on my little Ford but there are things I do that I could do without them.
Once a tractor is weighted it is much easier to leave it on and deal with it than guess at how much to remove for a particular job.
/ Weight is bad #42
Right. If is excessive then its excessive. That is fairly self evident, and most anyone would agree. The OP's point is made in the context of a long held and oft repeated belief that more weight is always better. You hear it here all the time. "Heavier is better." The seminar showed that this is not the case for many applications.
/ Weight is bad #43
Exactly. Traction is better, and weight distribution is key, not just weight.
/ Weight is bad #44
It takes a wide range of uses for filled tires to be a problem. If you don't do lawns I can hardly think of a reason not to load them. An otherwise unweighted tractor is almost always going to benefit from fluid in the rears. So mine are filled and ALWAYS will be. If I get wheel weights, that will be in addition to fluid, if I need them. Rolling resistance from fluid will never be an issue for my weekend warrior tractor.
/ Weight is bad #45
Lawns, other than ours is one of the reasons for the purchase, hence the unloaded tires, and suitcase weights.
Less stress on the tractor all the time is a better thing. For heavier stuff, our trusty 35 will do.
/ Weight is bad #46
Agreed. Weight on lawns is a bad thing.
There has been some debate about that. Seems like wheel weights and/or fluid in rears adds very little stress. Stress on the front axle is a different thing and probably a good reason to remove weight when not needed. Suitcase wieghts and removable FELS make that easy. Of course, bouncing a light front may be harder on the axles than weight.
/ Weight is bad #47
That is one thing I have wondered, a front end bouncing vs having a weight or 2 on it. When mowing, we use no weight, only time really is when the front tires feel light, or ground engaging work.
/ Weight is bad #48
I think the problem is that some people think of more weight giving better traction. They think more weight make the tire dig in more giving better traction. This is not true, the weight also makes the tractor sink in more and is that much more weight to get moving. Adding weight is all about balance.
/ Weight is bad #49
tell me you're not talking about rolling resistance with tire solution factor. It's not about ..
/ Weight is bad #50
bouncing a light front? Geo/bro whaaatt? oh.. wait I seen it on videos from LA usually w/chevies..
/ Weight is bad #51
We know that the CNH information is really targeted towards the AG tractors. So with that said, how many of us actually alter the weight on our utility tractors to match what task that we will be doing at a certain time? Do the guys that have cast iron weights actually add or remove them depending on what they will be doing that day and then change them again later that or the next day?
I have a bigger tractor than most here, but I for one do not. We have been told to use cast in place of fluid. What if you can't get enough cast iron on. I have twice the wheel weights on than what is recommended. No way was that enough weight, so I filled all 4 of my tires as recommended in my owners manual. Oh what a difference. Yes I am sure that for some of the things that I do that weight is over kill, but for sure when I am disking or doing other heavy dirt work, it is just right. As has been said before, there are charts to show you what the tire should look like and how much slippage you should have and my tractor meets that criteria at certain times. There is no way for me that it is ever practical to alter the weight to match a lighter duty function and then add the weight back on for heavy duty tasks. The tasks change to frequently, that is why I got a utility tractor.
/ Weight is bad #52
If you've never bounced the front of your tractor you must not have ever had the loader off, or never had anything heavy on the rear, or use your tractor only on pavement.:D
With my mower on the back (lifted) and no loader on or weights up front, even a slight indiscretion with the clutch (who me? never!) and the fronts will come off the ground.
/ Weight is bad #53
Actually, doing the math, it gets confusing. The OP (Messicks) posted that 100-130 pounds per PTO hp is in the correct range for the tractor to weigh. Many Kubotas are in that range already - no fluid - no iron weights - no implements - no FEL - no BH.
My kubota L3410 hst is 2880 pounds and 28.5 hp out the PTO. So the ideal weight is then 2850 pounds to 3705 pounds. With the FEL on it, it weighs about 1000 more than empty or about 3850 pounds - right over the max. But with no rear weight or tire fill, it will pick the back tires off the ground easy. So, tires are filled with CaCl2 about 800# making it about 4600-4700#. But it still does not dig well and still occasionally lifts the rears, so a 950# box blade is often used. Bringing the weight up to about 5500-5600#. Add 200# for the nut holding the wheel and it's about 57-5800#. Divide that by the 28.5 pto hp and you get 200 pounds per pto hp.
So, according to the presentation data, the tractor should be "ideal" as delivered for field work. But for FEL work, it was way light. How many of us really feel the tractor was ideal with no weight added?
jb
/ Weight is bad #54
Here is a picture that I saw a while back that depicts a properly ballasted tractor :)
/ Weight is bad #55
Love that picture.:D Probably has fluid in the front and rear tires with the weights.
/ Weight is bad #56
I think its a safe bet that its set up for pulling competition. Those guys really pile the weight on!
/ Weight is bad #57
For my "Hills of Kentucky" my Kubota 9540 has cast wheels and filled tires. It really reduces the pucker factor and puts the weight were it is needed.
Bake
/ Weight is bad #58
IMHO.. loaded tires are not a deahnel to a lwan.. i run my loaded tire tractors over my lawn and I don't have dead streaks in it yet... ;)
soundguy
/ Weight is bad #59
I found it easier to just ballast my tractor for the correct weight for it's application.. then use another tractor differently ballasted for different applications.. ;)
soundguy
/ Weight is bad #60
soundguy
Aren't you the guy with more tractors than acres? :rolleyes:
It's tougher for us guys that have more acres than tractors, by a factor of 100-1!
It must be nice to be the other way around on that ratio!
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A64553)
2025 HT360W Mini...
2016 Ford F-250 Ext. Cab Pickup Truck (A64556)
2016 Ford F-250...
2015 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2015 SolarTech...
2001 CATERPILLAR 924G WHEEL LOADER (A65053)
2001 CATERPILLAR...
2006 CHEVROLET TRAILBLAZER LS SUV (A65054)
2006 CHEVROLET...
