Looking For Some paint Info/Ideas
/ Looking For Some paint Info/Ideas #1
BSVLY
Desert Southwest
Kioti CK30 HST
Howdy:
A few years ago I posted here on this little project. I had purchased a place with 12 poles set in the ground and 4 of them were fire damaged. I had the four damaged poles cut down and about a year ago had a contractor that was putting up a steel garage also put a roof and cap on the remaining 8 polls. It gave us some decent parking shade.
Above P-Barn is 15 X 50 feet and has 10 foot eve height. Walled-in section is 15'X30'
I now want to move ahead to make a storage shed out if it, so we had another contractor partially build-out the walls this past month. I will eventually close out the walled-in area with a door and will leave the front portion open and use it for parking shade etc.
The eves are open to the inside all the way around and I plan to screen them off to prevent the birds from nesting in the rafters. I now want to paint or stain the inside of this building to seal the wood. Note:-this building will really "breathe" and the humidity inside will swing with the weather. How do I protect the inside wood from the elements?
1) Prime with Kilz2 and then paint with Exterior Acrylic latex? Sounds like a lot of work)
or.......
2) Shoot it with some sort of colored stain? I just want to seal the wood and give it a uniform color coat.
I would enjoy hear what some of you have done on similar structures and what you may recommend.
BTW- Notice the encroachment of civilization 40 miles in the distance ;)
Thanks
/ Looking For Some paint Info/Ideas #2
You could spray it with solid latex stain. If you go with a color similar to what it is now, it will go pretty fast. Home Depot sells a pretty good Behr exterior oil/latex hybrid solid stain for $20/gal.
Kilz and paint is great. But, it is going to cost you.
Wear a respirator, if you end up spraying it.
If you give up on the even color thing, you could use Thompson's water seal in a garden sprayer to waterproof it. (cheap)
Thanks for the suggestion. I looked at the BEHR site and found the Oil/Latex stain you mentioned. That is a definate top choice so far.
Thanks again
/ Looking For Some paint Info/Ideas #4
maybe spray it w/ linseed oil? i think that may be your cheapest alternative... good luck an plz post a finished pic!
2020 FORD F-600 SERVICE TRUCK (A60736)
2020 FORD F-600...
Great Dane Van Trailer 1989 (A61307)
Great Dane Van...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A60352)
Paladin 12in...
John Deere 5075E (A60462)
John Deere 5075E...
2020 DRAGON ESP...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
