Rear blade project.
/ Rear blade project. #1
fattyfat1
MY DEALER SUCKS, WA
John Deere 2305
picked up this blade from a Guy in LaCenter for 75$ I plan on adding ripper teeth that are removable because I don't have a box blade. three teeth about six or eight inches apart. I started welding the tooth bracket tonight. I'd also like to add a bracket for my suitcase weights to add some weight. any ideas?
/ Rear blade project. #4
Good deal for $75.
I would get some box blade scarifier teeth as they are only 20 - bucks each or so. Then some 4" angle and make a box for the teeth like a box blade has. Then you can raise and lower them as needed. See if you can mount it on the back side of the blade. That way it will both strengthen the blade and add more weight where it will do the most good.
/ Rear blade project. #5
Good deal for $75.
This is a very good idea.
one step ahead of you guys! got welded up today! thanks everyone for your ideas!
now all you gotta do is envision it green. after winter, off to blasting and painting!
/ Rear blade project. #8
Very cool idea and for the money you cant beat it. Now you just have to build ends for the blade and you will have a box blade with teeth.
/ Rear blade project. #9
Your dealer sucks but your tractor is green? I know of a doozy of a dealer 15 miles north of us who is marginal at best. La Center deer dealer was OK, not stunning but wasn't a train wreck. Loved the orange guy just down the road.
Greetings btw from the other side of the hill
Carl
i know exactly of whom you are referring! that is them. Jo-Bob at the front probably can't even tie his own shoes. the will try to sell you crap you don't need, always pining for the most expensive new tractor or part. my business goes to the kubota dealer unfortunately for the JD dealer. those guys are great! all my tractor needs are met there. they even carry JD green paint for me. I'm in Kelso, just up the road from you.
/ Rear blade project. #11
Wow, you work fast! 1 min from a mock up to full paint.
Nice job. I would have wanted the back bar to go full length, but that is ok as is. With the teeth close like that, you will be able to pull up rocks pretty easy.
One caution, be sure to pull the blade up when you turn or those unsupported teeth will twist up like nothing and quick too!
jb
/ Rear blade project. #12
Ahhhh... when you said lacenter I thought that was your home... I was referring to the deer dealer in that area. Watkins is where I assume you go, Those guys are killer... helped me a bunch and I have a PT. They even took the time to go to the website of PT and look at it to help me better describe the things I need....
All the best...
Carl
jb
i don't think my little tractor could pull a full length bar, plus less teeth means more passes, which = more seat time!! thanks for the tip on turning. thats not full paint. LOL!! i found a 2/3 empty can of JD green in the garage. when it's officially done, it will be blasted, primed, and painted properly.
All the best...
Carl
Watkin's is where i bought the ripper teeth today on my way home from the welding shop. very helpful and informative shop. the ridgefield dealer seems OK, as you explained earlier, we both are in agreement about which dealer is the turd w/out mentioning it's name.......
/ Rear blade project. #15
Can you raise the teeth up so that they are just about 2" lower than the bottom of the blade? That would be a good depth for most things. Typically, you don't want to have them way down unless you are really agressively breaking up the soil. I am concerned that the teeth may bend as they are sticking down a ways, but if you are in rock free soil it may not be a problem. Best way to find out is to try it out!
Post up some pictures after you get the paint dirty.
jb
jb
yes, when the teeth are all the way up, they are about 2 1/2 inches from bottom of blade. i will mostly be using it to prep the garden before tilling (clay soil = hard on the old craftsman tiller.) normally i get a truckload of sand and compost, then turn it over with my loader before tilling it in. the soils getting better, but three years later i still have lots o' clay. i can bury the teeth, and get deeper than my tiller can, add more sand, till, add more sand, till again, and hopefully be done! when we moved in, you couldn't even shovel it, would have been great for pottery though. the soil is ten times better now.
/ Rear blade project. #17
Sounds like your on top of it.
We should probably swap 1/2 of each other yard. I could use some clay in the sandy ground I have!
jb
/ Rear blade project. #18
Looks good.
One thing, don't have them engaged in the ground if (when) you make a turn.
They could bend that way, especially the deeper you have them. (Don't ask how I know.:))
Looks good.
thanks. great idea, i have a way of finding things out the hard way too!
/ Rear blade project. #20
Nice design and fabrication, FATTYF.
I don't think you will bend the ripper shanks with your 2305. Now a heavier
tractor sure could bend them (ask 3RRL).
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2019 PETERBILT 579...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
2025 12v Fuel Pump (A61568)
2025 12v Fuel Pump...
17101 (A55851)
17101 (A55851)
FENCE PANELS (A58214)
