Finally built a bridge
/ Finally built a bridge #1
RobA
Chester County, SE PA
Kubota L5030 HST
I've wanted to build a bridge across my creek for a while now. I thought about a culvert, flat bed trailer, etc but settled on wood both for looks and because wood is easier for me to work with. I also thought about engineering it to hold a truck or tractor but gave up on that since the bridge length wound up being almost 24 feet. I was able to use 3 beams so the longest span was almost 14 feet. It will be used for people, ATV's and horses. The only thing left to do is build up some approach ramps. Thanks to everyone here for their ideas and help.
Some specs:
length: 23'+
width: 8'
max height above grade: 5'
posts: 6 - 6"x6"
beams: 3 - double 2"x10"
joists: 7 - double 2"x8", 12" OC (glued and bolted together)
blocking: 2"x8"
decking: 2"x6"
And some pictures:
Posts set:
Beams up, joists started:
Joists done, adding blocking:
Decking done:
Working on railings:
Done:
Another view:
/ Finally built a bridge #2
Looks good Rob. Very sturdy. What's the plan for ramps?
/ Finally built a bridge #3
Horses ?
Edit; Never mind. Missed the 12" oc joists the first time.
I'd take a CUT across it.
I have an excavator coming this fall to do some other work. I may have him move some dirt to make the approach ramps.
/ Finally built a bridge #7
Yeah Rob, looks really good and the wood theme fits nicely in that creek crossing. Looks pretty sturdy too. I don't think it will fail myself.
/ Finally built a bridge #8
Nice job - sturdy and looks good, too.
The weakest link is where the beams parallel to the creek bolt to the posts. Watch those bolts for rusting over time.
/ Finally built a bridge #9
Great job on the bridge. Thanks for the detailed photos.
Very nice job!
/ Finally built a bridge #10
Nice job.
/ Finally built a bridge #12
Can you say picture perfect?
/ Finally built a bridge #13
Rob,
Looks very nice.
I noticed a few things in your pictures, and even though I don't really have any fear that it will fail, the life of it might be increased with a few changes. Since it's not a daily, high traffic type of struture, I could also be totally off base. If so, I apologize.
The beams are held in place with two bolts. That means that each bolt is carrying 50% of the load. I would add two more bolts and maybe even some Simpson Hangers. Spreading out the load and relying less on those two bolts would take allot of strain off of the wood.
How did you install the posts? A 6x6 is pretty sturdy and plenty strong enough for your loads, but the height of them above grade, especially in the middle, gives me some concern for racking. Adding some cross "X" bracing in both directions would stiffen it up, which you might not even notice right now, but will add years to the overall integrity and strength of the structure.
Eddie
/ Finally built a bridge #14
The beams are held in place with two bolts. That means that each bolt is carrying 50% of the load. I would add two more bolts and maybe even some Simpson Hangers. Spreading out the load and relying less on those two bolts would take allot of strain off of the wood..........
This is what I was referring to in post #8, Another approach is to notch the top of the post so that each beam sits on a shoulder of the post. I'm sure it is plenty strong for the intended use, as is.
Frequently decks are built with the same design, though nails may be used instead of bolts. New home owner has the whole extended family out on the deck to show it off and over she goes.
/ Finally built a bridge #16
Nice job. Looks like it belongs there.
What did you use to treat the posts below the soil line? I can see from pic #1 that they are "painted" or "dipped" in something...
/ Finally built a bridge #17
make shure you put some riprap upstream of the posts otherwise they will scour quickly.
Thanks for the interest, compliments and suggestions.
Eddie
I thought about using hangers but couldn't find any that would work with the way I bolted the beams to the 6x6's. I guess I could attach some 2x stock below each beam to provide some additional support.
The posts are sunk 3 feet and backfilled with concrete. I may add cross bracing but it seems very sturdy so far. If you look closely at the 3rd picture you can see where I left the 6x6's higher than the beams. That way the outside joists rest on the beams and are bolted to a post. That may take some pressure off of the beams.
I thought about that but leveling and aligning the beams was easier by bolting them to the posts. This way I was also able to bolt the outside joists to the posts.
Good eye, Nate. I used a copper based wood preservative on the lower half of the posts. I figured it was cheap insurance.
I started to use field stones for rip rap on the creek bank and around the middle posts. The posts on either end of the bridge never see water.
/ Finally built a bridge #19
Most engineered wood bridges have cross bracing on the upright supports. This would help your nice looking bridge in sturtural support and preserve it for many extra years. 2x's attachhed to uprights very good idea to releave strain on the bolts.
/ Finally built a bridge #20
Here's a small walk bridge I build for my mother's brook side flower beds. I got to use the tractor to carry it from my house to hers (about 3/4 mile). I wish I could have used the tractor to build the rock abbutments....
In the summer both banks along the brook explode with blooms.
Dean
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A61574)
2012 18ft Gastron...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
