Tires Foam filled tires
/ Foam filled tires #1
AnotherGrassFarmer
I recently bought a 3525. The first day out I punctured a front tire in four places with Honey Locust thorns. I have 6-8 acres of Honey Locust and Osage Orange. Since clearing this land is a requirement, and I don't want ot keep patching tires, I'm considering having the front tires foam filled.
Anyone done this and what were your impressions afterwards?
/ Foam filled tires #2
Foam is good but somewhat costly....If you have that much to clear, see what a local excavator with about a D6 CAT would charge for about 2 days to clear it up for you. Just a thought...BobG in VA
/ Foam filled tires #3
AGF,
Great to see another 3525 owner!! ;):p
Bob's suggestion on the dozer is spot on... I wouldn't tear up my tires with those thorns... the fronts are cheap compared to the rears! Also, unless you're cutting the trees down and dragging them away, bulldozing trees with your tractor is just tough on your equipment, especially if they have any size to them... a real dozer is much better suited for the job.
Where are you located?
/ Foam filled tires
I'm in Texas, about an hour north east of Dallas.
The tree clearing is an ongoing project. I'm cutting down the trees and saving the wood for fence posts. I'm not pushing them over with the tractor. Just being in the area is where I'm picking up the thorns. Clear the underbrush, cut down the trees, and then keep the area clear. I hope to reclaim about a third of the property that's now overgrown.
/ Foam filled tires #5
It works great, it is expensive and the tires will be real heavy. Sounds like the way to go for you.
/ Foam filled tires #6
I feel your pain. I live in south Texas and we have Mesquite and some other types of thorny brush. I had the front tires filled with tire sealant and that helped for awhile until I guess I ran out of the fluid from all the punctures. I've only had to fix my front tire once and it had about 4 holes in it, but I know more flats are coming. I can't avoid all the thorny bushes!! The back tires are not filled but have not been punctured by thorns, just pieces of metal. I've had to fix the back tires twice.
I'm seriously considering filling the fronts with foam. The neighbor filled his and his only complaint is the rough ride.
/ Foam filled tires
I just got the front tires back today. $156 for the pair. Very heavy. :)
/ Foam filled tires #8
I'm much like you - purchased a new tractor and within a week had flat front tires (locust and osage). Had them patched at a local tire shop and they were flat again within another week!
I went back and had them filled with foam. Cost about $100 each for the front tires. I have Ag tires and so far have not punctured one of the rear tires. It would be MUCH more expensive to fill the rear tires with foam.
Filling the front tires was one of the best decisions I made.
BTW - if I get a real novice person at the farm, I sometimes ask them to check the air pressure on the front tires. That brings about some smiles after we get past the joke I just pulled on them.
/ Foam filled tires #9
I had my front foam filled after thorns in pa country, best money ever spent gave me the weight ,plus the tires do not flex as much with a heavy load in the bucket.
Macdabs
/ Foam filled tires #10
I live in the same area as you do and also want to get my front tires filled with foam and was wondering where you had yours done. I have been told about a place in Dallas called Best Quick tires but I cant find their contact information anywhere. Can you send me some information about where you had yours done!
/ Foam filled tires #11
I had thick tire liners installed. That really helped.
/ Foam filled tires #12
Old thread but it is on topic and I didn't need to start a new one.
Who does foam tire filling?
Is that something the nearest tractor dealer (service department) can take care of?
I have been searching on Google but have not found such a place.
Thanks.
Kent B.
/ Foam filled tires #13
Kent, talk to the Bobcat dealer on E. Lincoln Hwy, CSR Bobcat Inc.. They don't do it but will know who does In Tally. Paul the owner is an old friend. By the way, take a big wallet when you go to get it done.
MarkV
/ Foam filled tires #14
I found a place in Midlothian, Texas to fill my front tires with foam. $110 per tire. Elete Tire is their name.
/ Foam filled tires #15
A fork lift tire place here used to do it
/ Foam filled tires #16
be careful using foam in CUT tires i have had good luck with it on my yanmar and was going to do it on my new bobcat until i read in owners manual not to use foam or it would void warranty??? i can not for the life of me figure out why but thats what it says. maybe something to do with extra weight/ to much traction i dont know dosent make any sence to me. would love to find out why.
/ Foam filled tires #17
finally found out why it was not recommended. Creates a rougher ride and doesn't allow the tires to absorb the impact the tractor takes. Not sure if they actually had problems with the tractors or just on the skid steer's butt The bobcat dealer told me that's why it's not recommended. I'll bet it was rough as heck on bobcats with foam filled tires probably a real kidney buster. Sure did like it on the front of my old utility tractor though didn't notice a huge difference in rougher ride but it was somewhat rougher. I think it was definitely worth the trade-off though. More weight never had a flat and tires held up well to the extra load for the loader.
/ Foam filled tires #18
This is old post, but still interesting. In this case, one might try, throw back to 1900s and change tires to steel wheels, like in early farm tractors.
I remember my Dad had story he told about old days. He drove delivery truck in 30s. "Boy, you have it easy today. We delivered groceries in
trucks with solid tires. The roads were mostly mud and could hardly get through in cold wet weather." The icing on the cake to his story,
"we had no heat in trucks and had curtains for side windows." If I remember right, he used to say he carried a 50 lb sack of flour on each shoulder
delivering to the family grocery stores. He never said anything about 2 wheel dollies. I don't think he was a union driver. Some say "I long for
the good ole days". I'm not so sure they were so easy, though.
Cheers.....Coffeeman
/ Foam filled tires #19
Some Mahindra tractors come with steel "shipping wheels/tires". They do look sorta like the old steelies on the old tractors. I saw pictures of the the Mahindra wheels once somewhere. My dealer said he tried to get some just for hoots but they wouldn't let him have them.
/ Foam filled tires #20
I have seen steel wheels on newer machines in Amish country.
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
Worksaver Terra Max Ripper (A64047)
Worksaver Terra...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
Cub cadet LTX1045 Lawn Mower (A63116)
Cub cadet LTX1045...
Informational Lot - Financing (A63688)
Informational Lot...
Bobcat T590 (A60462)
