Zero turn thoughts on common models
/ Zero turn thoughts on common models
In the info I've found for the models I'm looking at they all seem comparable. Around 18,000 to 18,500 fpm.
Rob
/ Zero turn thoughts on common models #53
Blade speed cannot exceed 19,000 fpm. Most commercial mowers are slightly below that limit.
/ Zero turn thoughts on common models #55
As I understand, It’s an ANSI standard based on how hard the blades will throw objects. ANSI says 19,000 is the maximum a mower can produce to conform with Their safety requirements.
It’s not a law. It’s something manufacturers follow to say they comply with ANSI which limits legal issues.
My understanding is Dixie Choppers do not follow the standard but all the other major producers do follow.
MoKelly
/ Zero turn thoughts on common models #56
I know my Simplicity Citation XT 27hp full suspension model runs a 18,500 tip speed. At full speed across the lawn at 11mph the cut is as good as at slower speeds. It's all about throwing the grass out the side quickly to allow a full blade to cut at speed.
/ Zero turn thoughts on common models #57
/ Zero turn thoughts on common models #58
For those who don't know it, Ferris and Simplicity are the same machines. Snapper is basically a Ferris without the suspension. All are made by Briggs.
/ Zero turn thoughts on common models #59
Yes,
I have a Snapper Pro s200xt. It is basically a Ferris 3200 without the suspension
/ Zero turn thoughts on common models #60
I saw a guy at lowe's yesterday with an ariens zturn on his trailer. I asked how he liked it etc etc.
He loves it and went on to tell me Graverrly, Kubota and ariens were all made by kubota?
Anybody know this for sure and are similar models the same machine?
Trying to keep up with this 3rd party private label BS is a full time job!
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
2015 Ford Fusion Hybrid Sedan (A59231)
2015 Ford Fusion...
