Zero Turn suspension forks?
/ Zero Turn suspension forks? #3
I've got them on my Hustler as well. Not a "Boulevard Ride", but better than stock.
/ Zero Turn suspension forks? #4
I put them on my Deere Z960. Definitely noticed an improvement.
You will get the most benefit out of a full suspension seat, but the entire "ComfortGlide" setup will run you around $1200. Also adding some Tweels to the rear (and maybe the front but I haven't tried that yet) will smooth out the bumps as well.
/ Zero Turn suspension forks? #5
I don't see them listed for my Z530R, so I may make a phone call or just wait...
/ Zero Turn suspension forks? #7
What suspension seat do you have? I'm. Looking at some, but they've only got one inch of travel.
/ Zero Turn suspension forks? #8
I bought the Deere one that comes on the higher-level Z900 models. It's weight adjustable and has armrests.
There is also an additional frame for under the seat that is the Deere "ComfortGlide" system. I didn't get that at the time but am considering adding it. When you get those 2 things together it makes a huge difference in ride quality over the lower-level seats.
My Z530R came with the "ComfortGlide" seat "system". It's a great seat, and does help, at least a little. The "R" package/upgrade is worth every penny - seat, LED lights, foot rests, etc...
/ Zero Turn suspension forks? #10
/ Zero Turn suspension forks? #12
I went and picked up fuel at the depot and a woman was mowing with a stand-on ZTR. She had quite the bouncy ride too. Our drought has made the ground rough and unforgiving so it sure is a hard way to make a living right now. There has to be a way to suspend them mowers so they ride better. (like Ferris?)
/ Zero Turn suspension forks? #13
The link to their site is in the first post. You can look.
It didn't list 1 for the 5R series you had mentioned calling them about your z530R . so I thought they may have steered you in what model may fit?
My SIL has a Gravely, with some sort of suspension. He loves it but, it cost him like $10k...
/ Zero Turn suspension forks? #15
Ok after doing some homework ( reached out to the company and never received a response) I found the model 500 unfortunately won't fit my Z545R. what I did was research the models they said it fit . looked up the part numbers from John deere. and found out it's made for a 5 inch tire and is 5.5 inches wide.The R500 series uses a 6 inch wide tire. and has a 6.5 inch width between the forks. So im hoping they make a wider 1 for the R500 series soon 🙏.
/ Zero Turn suspension forks? #16
just called the company and they have no intentions of producing 1 a inch wider. bummer.
Thanks for saving me the research time. Yeah, bummer. I'm not swapping to smaller tires, either.
/ Zero Turn suspension forks? #18
I put them on my mower and did not see that big of a difference. I still think the comfort glide or scags suspension sled are the most comfortable way to go for a zero turn.
/ Zero Turn suspension forks? #19
the guy had mentioned that they had rubber in them. and couldn't be welded on.
75 TON IRON WORKER (A64280)
75 TON IRON WORKER...
2025 X-Pro Victor Mini Dirt Bike (A61574)
2025 X-Pro Victor...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2001 Sea Breeze RV (A62613)
2001 Sea Breeze RV...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
