YT359c top link!
/ YT359c top link! #22
Hi Desertsasquach,
I would appreciate knowing what you decided on as I am a bit new to this and want to get a top n tilt for an open station YT359. I don't know what the "next longer length" item would be when looking at the top kits. Also would like to know what restrictors I would need. Just learning about this, so a little confused.
If you go onto Summit's website and look at the top links, this is the second one that I purchased. 280mm (11") Stroke (21" Min - 32" Max) The one shorter link barely tilts my implements back,...which is the one they recommend when you put in your measurements. It tilts it way forward, but not far back at all. I have the factory quick hitch. I really needed the longer cylinder because my TR3 Rake will not tilt far enough back to use the combs only.
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
Kubota L4701 (A53317)
20' SINGLE AXLE INDUSTRIAL TRAILER (A59823)
20' SINGLE AXLE...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
2021 FORD F-150 STX CREW CAB TRUCK (A59823)
2021 FORD F-150...
2021 Caterpillar 299D3 (A60462)
2021 Caterpillar...
