You're method of 'chaining'
/ You're method of 'chaining' #21
I use to lay them out flat, drive on them and then lock them in place..but I was never REALLY happy with how tight I could, or in this case, couldn't get them...and not centered well. I have since started jacking up the rear end of my garden tractor, and "rolling" the chains onto each tire...I also deflate the tires a bit, so they are soft...I then install the chains, and then reinflate the tires to about 2psi under max pressure. This keeps the chains nice and tight, and I never have any problems on my driveway.
/ You're method of 'chaining' #22
I think the answer for the best method really depends on the factors the OP posted. On my little Cub, I can just toss the chains over the top of the tire. Plenty of clearance and not much weight. On the TC40DA, I hook a bungee cord between the wheel slots, drive forward, get off a couple of times to make sure they are straight, but have no heavy lifting to do. I think all these methods have their place.
/ You're method of 'chaining' #23
I haven't put chains on tractor since I got the 4wd in 2008. With the 2wd if I would drive on chains and pull them up over. Now I use the chains for temporary tractions. In fact I leave them in the truck for weigth and traction if needed. I have used them to get the truck or a neighbour unstuck more times than the tractor. Having used 2wd for many years, you are a lot 'smarter' about what you do and where you go so if you do get the 4wd stuck, you're in for a battle.
If your wheels are spinning (tractor or vehicle), if you lay your chains out flat in front of (or behind) your drive wheels and drive up on them most of the time it will get you out. (Don't have a heavy foot on the gas or you'll spit them out pretty quick.) If I go to the neighbours to blow snow I'll throw a shovel and the chains in the bucket and go. More than once had to use them for temporary traction.
Donnie
/ You're method of 'chaining' #24
I think my first challenge will be to find those chains under the snow we just got!
2010 Transcraft 35ft. Tri-Axle Aluminum End Dump Trailer (A64556)
2010 Transcraft...
Trump 2025 Sign (A64557)
Trump 2025 Sign...
Alligator Statue (A64557)
Alligator Statue...
Smalline 4in. Double Diaphragm S/A Towable Trash Pump (A64553)
Smalline 4in...
Kubota SVL75-2 Compact Track Loader Skid Steer (A64553)
Kubota SVL75-2...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
