Your towing rigs and trailers
   / Your towing rigs and trailers #3,881
Nice new truck 4570! That a diesel?
   / Your towing rigs and trailers #3,884
550 cat 13 holes to choose from and 2 speed rear ends what can go wrong.
   / Your towing rigs and trailers #3,886
   / Your towing rigs and trailers #3,888
650 then? That year and HP? Mine was a 05 650 proloader with the 230hp and Allison.
The door badge and title says 750 and the GVW is 33k and air brakes. 245 hp.
   / Your towing rigs and trailers #3,889
I'm surprised, most of the 6spd trucks I see are 650, the 750 seems to usually get the 6+1/7spd trans with the Cummins or Cat options. I assume the trans is an Eaton.
I really want another 650 cummins Allison combo but can't justify it right now.
   / Your towing rigs and trailers #3,890
Another couple gears wouldn’t hurt it.
   / Your towing rigs and trailers #3,891
I always lusted after a 7spd when I driving my buddies IH rollback with the t444e and 5spd. It needed all the help it could get!
   / Your towing rigs and trailers #3,892
This Cummins will run circles around the DT trucks I’ve had. I’ve never driven a 444 but I think they’re even weaker than a dt466. My buddy runs a loader in the quarry and there’s a truck with a 444 that won’t come out with over 7 tons on.
   / Your towing rigs and trailers #3,893
Agreed, the 444 is pretty much the same as the 7.3 powerstroke with a different HPOP and typically lower hp/higher tq. They are definitely not as strong as the Cummins in med duty applications and I don't think were offered above the 600/650 and IH 4700.
   / Your towing rigs and trailers #3,894
And the 7.3 was weak in a pickup. Who thought derating it and slapping it in a medium duty was a good idea? I really wanted something bigger than the little 5.9 but it actually does pretty good. If it had more gears or would be a lot better.
   / Your towing rigs and trailers #3,895
We have 2 Freighter medium duty straight trucks with the 5.9 and 6 speeds. No one will drive them. They are too gutless. We have some newer ones with the 12.7 Detroit and Allison's in them. Much better.
   / Your towing rigs and trailers #3,896
My truck isn’t geared to run over 60 mph and probably doesn’t have the power even if it did but it pulls good in that range. Also there’s a wide variation in power from a 5.9. I’ve seen them as low as like 175 hp to over 300 from the factory.
   / Your towing rigs and trailers #3,897
The 230 was a little weaker then I'd have liked but still didn't have any problems running 70-80 at 26k+ lbs.
My buddy had the same truck with the 260hp and it pulled pretty nice.
I think the Allison makes a lot of difference in how they pull.
   / Your towing rigs and trailers #3,898
The way they changed the output is similar to the Cummins where they are lower HP for longevity but have the higher torque output.
But yes it is a turd in the larger trucks, I think it was rated at 175hp
   / Your towing rigs and trailers #3,899
I’ve never driven a medium duty with an automatic other than a bus. You think they pull better? I have a 5500 with an 8.1 with an Allison behind it but it’s been non operational every since I’ve had it.
   / Your towing rigs and trailers #3,900
What? Only when compared to today's engines. Back then the 7.3 powerstroke was one of the best, most powerful engines you could get in a pickup and could easily last 500k miles.
They are even still sought after today by many.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
PALLET OF CHROME FENDER FLARES (A60432)
PALLET OF CHROME...
2001 Pierce Spartan Model Tilt Pumper Fire Truck (A59230)
2001 Pierce...
2016 FORD FUSION SS (A60430)
2016 FORD FUSION...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
