Your towing rigs and trailers
/ Your towing rigs and trailers #3,881
Nice new truck 4570! That a diesel?
/ Your towing rigs and trailers #3,884
550 cat 13 holes to choose from and 2 speed rear ends what can go wrong.
/ Your towing rigs and trailers #3,886
/ Your towing rigs and trailers #3,888
650 then? That year and HP? Mine was a 05 650 proloader with the 230hp and Allison.
The door badge and title says 750 and the GVW is 33k and air brakes. 245 hp.
/ Your towing rigs and trailers #3,889
I'm surprised, most of the 6spd trucks I see are 650, the 750 seems to usually get the 6+1/7spd trans with the Cummins or Cat options. I assume the trans is an Eaton.
I really want another 650 cummins Allison combo but can't justify it right now.
/ Your towing rigs and trailers #3,890
Another couple gears wouldn’t hurt it.
/ Your towing rigs and trailers #3,891
I always lusted after a 7spd when I driving my buddies IH rollback with the t444e and 5spd. It needed all the help it could get!
/ Your towing rigs and trailers #3,892
This Cummins will run circles around the DT trucks I’ve had. I’ve never driven a 444 but I think they’re even weaker than a dt466. My buddy runs a loader in the quarry and there’s a truck with a 444 that won’t come out with over 7 tons on.
/ Your towing rigs and trailers #3,893
Agreed, the 444 is pretty much the same as the 7.3 powerstroke with a different HPOP and typically lower hp/higher tq. They are definitely not as strong as the Cummins in med duty applications and I don't think were offered above the 600/650 and IH 4700.
/ Your towing rigs and trailers #3,894
And the 7.3 was weak in a pickup. Who thought derating it and slapping it in a medium duty was a good idea? I really wanted something bigger than the little 5.9 but it actually does pretty good. If it had more gears or would be a lot better.
/ Your towing rigs and trailers #3,895
We have 2 Freighter medium duty straight trucks with the 5.9 and 6 speeds. No one will drive them. They are too gutless. We have some newer ones with the 12.7 Detroit and Allison's in them. Much better.
/ Your towing rigs and trailers #3,896
My truck isn’t geared to run over 60 mph and probably doesn’t have the power even if it did but it pulls good in that range. Also there’s a wide variation in power from a 5.9. I’ve seen them as low as like 175 hp to over 300 from the factory.
/ Your towing rigs and trailers #3,897
The 230 was a little weaker then I'd have liked but still didn't have any problems running 70-80 at 26k+ lbs.
My buddy had the same truck with the 260hp and it pulled pretty nice.
I think the Allison makes a lot of difference in how they pull.
/ Your towing rigs and trailers #3,898
The way they changed the output is similar to the Cummins where they are lower HP for longevity but have the higher torque output.
But yes it is a turd in the larger trucks, I think it was rated at 175hp
/ Your towing rigs and trailers #3,899
I’ve never driven a medium duty with an automatic other than a bus. You think they pull better? I have a 5500 with an 8.1 with an Allison behind it but it’s been non operational every since I’ve had it.
/ Your towing rigs and trailers #3,900
What? Only when compared to today's engines. Back then the 7.3 powerstroke was one of the best, most powerful engines you could get in a pickup and could easily last 500k miles.
They are even still sought after today by many.
2010 CATERPILLAR 924H WHEEL LOADER (A60429)
2010 CATERPILLAR...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2012 Ford F-350...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
