Your last generator Maintenance Run
   / Your last generator Maintenance Run #7,063
So, here's something new, that came up this week. We had high winds and lost power for most of the day, earlier this week. No worries, I fired up the ever-reliable portable genny, shut of the main breaker and back-fed the house. Basically no interruption, we were able to keep running our home business all day.
When I could see from the digital meter outside that power had been restored, I shut down the generator and switched us back onto mains power.
Then I went to fire the generator back up, unloaded, to close the fuel valve and run the thing dry for storage. But the automatic starter did not want to turn the thing over, and then pulling the rip cord was so tough that the cord was ripped out of my hand.
Anyone experience this before? I honestly don't know if it's because there was some perceived load on the thing (charged PF-correction capacitors in output regulator?), or because of the engine itself. A few minutes later I was able to turn it over, but still a harder pull on the cord than usual.
Your posts lead me to expect that you are a regular checker/changer of Oil, so that one is checked-off.
My first response was Hmmmm.... (def odd). Then I thought of someone who recently stopped by here (..racer ID ?) talking about correcting a normally well behaved gen..... sounded like major carbon problems, which did get blown out once addressed.
Other than a part(s) deteriorating in the engine/starter, carbon (esp. dis-lodged) is the one thing I can think of that could possibly add friction.
Combustion chamber cleaner topside, and something like a dab of Seafoam in the crankcase, followed by a run then oil-change is what I might try.
That (above earlier post) was an interesting recovery, well done. IIRC, the OCI mentioned was 100 hours - that may well be factory-spec (I haven't researched the engine posted). I'm used to the Briggs spec of 50 hours - for air-cooled/small sumps, I don't like to take mine past that.
Multi-week outages (or construction site use)..... tough on everybody, including the MTCE scheds......
Let us know how this goes....
Rgds, D.
   / Your last generator Maintenance Run #7,065
Maybe the unloader on the exhaust valve is sticking? Or compression release is not working properly?
   / Your last generator Maintenance Run #7,066
lol... esp. that machine. I usually change the oil after each use, as I never know how long it will sit until the next extended outage. We sometimes go 3 years between uses, so I just re-prepare it for storage after each usage, knowing it'll be ready to go the next time.
Anything is possible. But spark arrestor is totally clean on the muffler, so I doubt there's much of a carbon problem. Machine is also very low hours, only 70 hours on the clock.
Interesting thing, I just went out the garage and tried the pull cord. A little tough on first slow cord pull, definitely building some compression, then pulled real easy after that.
Whatever that is, it's sounding really plausible. Not familiar with exhaust unloader valves, other than compressors, so I'm going to have to research this.
   / Your last generator Maintenance Run #7,067
Messed with the two portables today. Tried to start the bigger one a few days ago and nothing. Pull'n, pull'n', pull'n 'n nothin'.
Neither has been started in months.
Went at the HF inverter first this morning. Fired up on the third pull. Added a little Seafoam clone and let it run for an hour or so.
Then to the bigger no brand/generic that I've had for too many years. Drained the carb bowl and the gas smelled funky as expected. Pulled the fuel line and drained the tank. Added some Seafoam clone, StaBil and fresh gas. Still pullin' and not firing.
It has a toggle switch to turn on an off, so I'm thinking the switch went bad. Decided to pull the plug for giggles. It wasn't wet, but wasn't dry either. Pulled the rope a few times to air the cylinder out. Gave a it a shot of carb cleaner (no starting fluid on hand), put the plug back in and it fired up on the second pull. Let it run for a few minutes, then turned the gas valve off and let it run it self out.
It needs an oil change for sure and I guess a plug since it's the original.
But at least I know they both start.
   / Your last generator Maintenance Run #7,068
But….you didn’t drain the carburetors. Setting yourself up for round 2 🄓
I find gasoline today, loses volatility quickly.
New plug, never a bad choice, esp. with hours piled up. People use varied storage techniques.... if it's working well... keep doing.... if not, shift strategy..... anecdotal reports piled up here, lead me to believe that regional fuel variations will cause successful techniques from one geography to have less traction somewhere else.
YMMV.... pun intended....
Knocking wood w. my foot, while typing...... shifting to (carb) wet storage years back (Stabil or equiv) has worked well for me. To attack the problem from another direction (enzyme), I'll go the Startron route at times.... looks like they've added several brand extensions since I started using it.....
Fuel Additives
Rgds, D.
If you have access to it, nothing beats AvGas for storage.
Sigh.....sadly, I don't.
Had a chat with somebody I work with, he used to fly, and wrench (certified) on light-planes, but he/I have no contact there today.
Rgds, D.
   / Your last generator Maintenance Run #7,072
Cranked up the beast today. It gets the weekly exercise runs, but doesn't make power for those. I had a three or four hour outage a couple of months back, but no run under load since then. Flipped the main disconnect this morning to simulate an outage and let it fire up and switch over. Did that in about 20 seconds.
This UPS doesn't know the difference between Utility Power and Generator power though. It just knows AC voltage.
Gave it a work out using a bunch of hot water and running a few loads of laundry.
Ran it about three hours then switched back over to utility.
Not enough fuel usage to even notice
We benefit from Exercise, so do they ^ ! (y)
Rgds, D.
   / Your last generator Maintenance Run #7,074
I read this and chuckled.
bragging rights on biggest single cylinder
Introducing DuroMax's XP15000HXT – the LARGEST
single-cylinder, tri fuel generator, on the market
and utilizing the world's only 670cc single-cylinder oil cooled engine!
I think I'd be more impressed if they talked about pressure lubrication and an oil filter.
which they don't...but instead of calling engine air cooled, which it is, they call it
"oil cooled". Really? that's a stretch by splash lubrication.
Not generators, but on a different topic.... Baffling Them with Heifer-Dust was mentioned @ work yesterday.....
W/O an oil pump, not doing much for heat exchange with Oil..... add pump, cooling jets under a piston can be useful, but I suspect that ad may have been a typo.
I think I posted it on here recently, a screenshot from SpaceWeather.com - AI quote, on their landing page. Described all the "stuff" AI is writing on the web, then went on to say "If you find a mistake on our website, rest assured it was done by a human". I liked that one.....
Rgds, D.
   / Your last generator Maintenance Run #7,076
Rgds, D.
Reminds me of the old ā€œ humans make mistakes, but if its totally xxxxxxup, a computer did it.ā€
   / Your last generator Maintenance Run #7,077
51 years old, and it's still 26 of the best minutes ever aired on TV:
If you haven't seen it, a computer glitch declared Archie dead.
Back When.... If your Operation is Dis-organized, when you automate, you just get Automated-Disorder......
Computers are good @ making More Mistakes, Faster.....
Shopping @ Wally World today..... cashier had to print the lady in front of us a whole pile of gift-receipts, which seemed to confuse the new terminal they just got in. Standing there, watching food defrost, while she struggled to reset the terminal..... Supervisor had no better luck..... had to open another terminal/lane, for us to reload with our order.
Doesn't take grid-down, or another dramatic event, for things to grind to a halt.....
Rgds, D.
I don't remember that one.... but I can already picture The Look, from Archie......
(Thanks - Will watch later).
Rgds, D.
   / Your last generator Maintenance Run #7,080
Rgds, D.
Not my favorite episode of the series, but honestly... even an average episode of that show was better than the best from many others.
The one where Edith was going thru menopause was probably the funniest one I can remember.
2024 JCB 220XLC EXCAVATOR (A60429)
2024 JCB 220XLC...
2021 CATERPILLAR 259D3 SKID STEER (A60429)
2021 CATERPILLAR...
2015 Forest River Rockwood Freedom S/A Pop Up Trailer (A59231)
2015 Forest River...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
Traxmax Stand-On Track Loader Skid Steer (A59228)
Traxmax Stand-On...
TANK MANIFOLD (A58214)
