Your last generator Maintenance Run
/ Your last generator Maintenance Run
Modified is what my 1990 inverter is and it runs all my power tools and light boom but it will not run a Mikita or Dewalt cordless tool battery charger.
Haven't chased it down recently, but I know that Dewalt used to have a Table, that listed which chargers would tolerate generators, and which ones would not.
Rgds, D.
Some sensitive electronics like UPS systems “sometimes” have issues with the dirtier sine wave that 2 pole generators put out. That being said, ive run my house off of 2 pole generators since 1996….heck, i built my house off of a generator, and ive never had any issues.
My generac whole house is a 2 pole unit, so technically its somewhat dirty power. But while on the generator, all my electronics including 4 UPS systems have never had any issues.
My 22kw generac only cost $4500 back when new…..well, mine was free (but thats another story). I like inverter units made by Honda, but they just want too much for them. I was looking at one for use around property (like the quiet aspect), but bought a briggs 6.5KW for about $500 as opposed to the nearly $4000 honda wanted. Ill live with the noise. And it runs my skill saw and drill and wire feed welder just fine.
Interesting THD discussion.
I recall an article better part of 20(?) years ago in Homepower. Regular writer (Willy ____ ?), who was a industrial electrician. The high-end inverters (electronic box, not the modern gen) available then, had less THD than what Line Voltage often was, in many areas.... as tested with an Agilent power-analyzer.
The various comments exchanged here just now, have me wondering about the flywheel-effect of a larger generator. THD will matter, but I'm wondering about Rate of Change excursions (voltage, Freq, THD) with smaller generators, as the reason Some Things Die, while others Keep The Smoke Inside.....
We All Know.... These Things Run on Smoke !!!!
Rgds, D.
Northern CA may again have the opportunity for generator power as a possibility for power safety shutoff even announced due to high temps combined with wind.
Stockpile those (charged) Tesla batteries ! Those Santa Anna's (sp?), that's a New Thing, correct ? :cool:
Rgds, D.
/ Your last generator Maintenance Run #6,864
Can I bother you again, for the brand-name and model if they have one ?
Couldn't make out a name in your pic, and that 411 ^ could save me a lot of time on Amazon !
Thnx, Rgds, D.
I posted the link above, but here it is again Amazon.com
/ Your last generator Maintenance Run #6,865
First day of the quarter; ran my Generac 24kW for about an hour.
/ Your last generator Maintenance Run #6,869
INFORMATION: Y'all that have drills and other power tools that have
a chuck like the drill if it gets a little stiff when inserting drills etc spray
with some silicon spray will help to keep it free whellin
willy
/ Your last generator Maintenance Run #6,870
Checked my generator today (yellow light on) and it’s calling for an oil change. Have to do that Wednesday.
Did oil & filter changes on my wheel horse tonight. Greased everything up and sharpened the blades.
/ Your last generator Maintenance Run #6,871
The control module on my Briggs & Stratton Q6500 (see picture) 'fried' a few months ago. Bought it new from Home Depot in 2018. Only use has been for camper and home back-up, so less than 20 hours total on the unit. Failure occured at the end of a ~1 hour home power outage. All home back-up power is connected thorough a Reliance 6-circuit transfer switch. Still don't know the cause of failure but the engine has always started easily so I decided to replace the control module.
Ordered a replacement from Walmart (IPC Store, Wilmington Delaware) for $525 (with tax), and after one 'wrong part' shipment, got the new one installed yesterday and generator is now working fine. Reassembly of shell was tricky but unit seems solid again. Just could not bring myself to pay the new Honda inverter prices for my use case, even though the quality & reliability difference is well documented. This is the 3rd generator I've owned. Hope I don't hafta but another.
/ Your last generator Maintenance Run #6,872
Shame they potted everything in like that. Understandable, those things will vibrate the components off the board without it, and many of those potting compounds offer higher thermal conductivity and protect against ionization breakdown. But it looks like it could have been a simple $3 repair, otherwise.
Getting Things Done ! (y)
That reminds me..... :cool:
Rgds, D.
Fingers crossed for you on the new board (lasting).
If you haven't already, re-visit existing generator ground wiring - connection integrity, and what Briggs grounding requirements are.
Can't point to a particular case of grounding taking out an Inverter unit (yet)..... just "feels" like they aren't going to be less-sensitive to Grounding issues than olde pure rotary setups....
Rgds, D.
/ Your last generator Maintenance Run #6,875
Not sure how to feel about this. Last January we had our big ice storm. Checked the 27 year old Homelite 4400 Watt generator in December with new gas and oil and checked oil and stuff and cleaned the air filter, replaced the gas filter. It always started on second or third pull. Okay..... check that off and add some stabilizer to the gas. So we get this ice storm. Utilities said it will be a week or more to restore. No utility power for 8 days. Wife was really mad about the situation. Damn generator would not start, ..... pulled and pulled, had spark, and cleaned the carb in the cold. And made sure it had oil and was level. Made an attempt to start and work on it everyday to no avail. But I didn't have any Starter Fluid. We stayed out of power for eight days till utility came back on. We figured its time to get a new one, so we are looking these up online.
Just for laughs, I pull the gen out, this week, late August, for one last try before replacing it. Maybe I can get $50 for it as non-running. Starts on second pull and purrs like a cat. WTF....
/ Your last generator Maintenance Run #6,877
Sounds like the old corn gas syndrome.
That may have been the case. I always ask for clear, but the attendant might not have known what I was specifying, to put in the can.
/ Your last generator Maintenance Run #6,878
Yup….that is always the way. Thats why i have 3 generators.
I did the same thing with my portable 2 ton winch. I went to help a friend haul his kubota side by side to repair shop. I tested it prior to loading in truck. Got to site…..no work. I messed with it for an hour, than we found a hand crank winch to load it. Frozen transmission and 4 flats. Took over 1.5 hrs to load it.
I get home and was going to tear into it, but when i hooked up battery, it works great.
/ Your last generator Maintenance Run #6,879
I wonder what other people do to get the noise level down. My gen is LOUD. Tried adding an automotive muffler, but that didn't really work. And tried running the exhaust under water. That also didn't work. Figured out if I set it up to reflect noise away from the house, it is much better. The noise is in the single piston engine design. Even outside on the ground, we can feel the vibrations inside, panting the windows.
/ Your last generator Maintenance Run #6,880
kirkawilson what is the part number for your control module?
willy
John Deere 25A Flail Mower Tractor Attachment (A59228)
John Deere 25A...
UNUSED IRANCH MINI HYD AUGER SET (A60432)
UNUSED IRANCH MINI...
PALLET OF(3) CABINETS & (5)BOXES OF CARPET SQUARES (A60432)
PALLET OF(3)...
(9) 55 GALLON METAL DRUMS (A60432)
(9) 55 GALLON...
57" HYD LOG LOADER GRAPPLE (A60429)
57" HYD LOG LOADER...
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A60430)
UNUSED SDLANCH...
