   / Your last generator Maintenance Run #6,841
Some sensitive electronics like UPS systems “sometimes” have issues with the dirtier sine wave that 2 pole generators put out. That being said, ive run my house off of 2 pole generators since 1996….heck, i built my house off of a generator, and ive never had any issues.
My generac whole house is a 2 pole unit, so technically its somewhat dirty power. But while on the generator, all my electronics including 4 UPS systems have never had any issues.
My 22kw generac only cost $4500 back when new…..well, mine was free (but thats another story). I like inverter units made by Honda, but they just want too much for them. I was looking at one for use around property (like the quiet aspect), but bought a briggs 6.5KW for about $500 as opposed to the nearly $4000 honda wanted. Ill live with the noise. And it runs my skill saw and drill and wire feed welder just fine.
   / Your last generator Maintenance Run #6,842
yeah, you want a pure sine wave inverter, not a modified sine wave.
A lot of UPS put out a modified sine wave, that's junk!
   / Your last generator Maintenance Run #6,843
My new UPS doesn’t like running on generator power. I think it happens when the well pump kicks on. The UPS just shuts down.
   / Your last generator Maintenance Run #6,844
A nice used 25-40HP tractor to run the PTO generator and your all set.
Log into Facebook
Why do you say " It's also an inverter generator which, unlike the PTO genny, is safe for electronics."
I have had absolutely no issue with electrics on my pto generator nor has the farm and we have been using them from the 60's.
Depending on the quality of the inverter they can and have had issues with electronics as they are a modified sine wave and depending upon how many steps they make to make the full modified sine wave is important.
They are generally not modified sine wave. I haven't seen a modified inverter generator sine wave, most have THD below 3%
   / Your last generator Maintenance Run #6,845
UPS's have issues with the frequency drift, not a dirty sine wave, they generally want around .5 hertz deviation, i have not seen a mechanical generator with a non electric governor hold better then 1 to 2 hertz
   / Your last generator Maintenance Run #6,846
Modified is what my 1990 inverter is and it runs all my power tools and light boom but it will not run a Mikita or Dewalt cordless tool battery charger.
   / Your last generator Maintenance Run #6,847
ive been told there is a way to adjust UPS devices to use with a generator, but i didnt need to do that with mine. my generator holds 60HZ very well.
   / Your last generator Maintenance Run #6,848
higher end UPS have settings deal with this, most consumer cheap units, do not (they have a sensitivity thing, but that is generally related to voltage not frequency (I have 13 ups's in my house, and have gotten burned by this, until I went inverter generator)
   / Your last generator Maintenance Run #6,849
Exactly. "Pure sine wave" is pure marketing bullsh*t. There is no such thing, other than in theory. Check the THD spec, that's the proper metric.
   / Your last generator Maintenance Run #6,850
I've run my pto generator on at least a half dozen different tractors non of them had an electric/electronic governor and all of them have held the hz to under 1 hz except when I tried to use the IH574 on the 1000 rpm shaft at half throttle then it was not stable enough.
I know that many inverter generators and power supplies advertise pure sine wave power. I have not stayed on top of the latest and greatest power systems but I know of no way to get pure sine wave except from a rotating field any "solid state" device is going to be a modified sine wave it may have enough steps and buffering to be almost indistinguishable from a true sine wave but it is still a modified sine wave.
WhisperWatt DCA-85SSM 85kVA Towable Diesel Generator (A55973)
WhisperWatt...
24" X 36" ROLLING METAL CART (A58374)
24" X 36" ROLLING...
2013 Wanco WTSP Folding Solar S/A Towable Arrow Board (A55973)
2013 Wanco WTSP...
2014 Toro Z-Master 5000 Series 72in Zero-Turn Commercial Mower (A56857)
2014 Toro Z-Master...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2015 Peterbilt 567 QMC 8060R 40 Ton Tri Axle Crane Truck (A55973)
2015 Peterbilt 567...
