YM336D - Started knocking loud while tilling
/ YM336D - Started knocking loud while tilling #231
CarDoc, Sounds real good..I believe in good head bolts..and fasteners. There is no sinking feeling as when a bolt goes soft or suddenly snaps...I also hate bubbling head gaskets, so i seal the threads...Some bolts are good for only one time...
/ YM336D - Started knocking loud while tilling #232
A quick hijack but related to the last post and i will then yeild back to this interesting post.
Removing the exhaust manifold in my Saturn yesterday as it was broken and leaking. One stud snapped offf at the head. And it was one of the few that i put a bit of foward pressure on before i backed it out. I think it was weak or overtorqued at the factory as it twited off with very little pressure, actually about half of what was exerted on some of the others. I now am going to see if there is enought left to weld a nut to (i dont think there is) then have to try and drill it out!! Seems like its always something!!
Any tips i you wanna throw at me i will take. I m sure Domush can use them when trying to remove his exhaust on that as well.
/ YM336D - Started knocking loud while tilling #233
Well my first rule is never heat anything I will undoubtedly have to drill later when for example my weld fails or twists off the last bit to grab onto which they almost always do on this type work thats #1. :D
Rule #2 (& 5 are close) is always drill a small hole exactly in the center and all the way straight thru and spray oil it inside and if at all possible I do that when I am shutting the lights off for the day.
Rule #3 is use sharp bits! I always have a brand new box of cobalts just for this they dont drill anything but broken exhaust studs etc.
Rule #4 drill up a step at a time until its tap size for that hole and tap it with a good USA made tap. Now sometimes if I did my job right I use a reversed bit and at the last step of drilling sometimes just sometimes the rest will back out and only minimal thread cleaning is required.
Rule #5 is sometimes I take a cut off wheel and make a sideways cut like for a screwdriver bit to fit in on a flush bolt and I extend it into the casting if necessary and air/sprayoil all the chips off good, fact I almost always do that first if I think I can get away with it and then drill my pilot just depends on how stuck they may be.
Then I get a nice sharp flat head screwdriver and a wrench on it and give that a try. Sometimes a torch can help heat the metal around but as soon as you go a bit too far forget the easy drilling you have tempered steel then and only cobalts will drill only reasonably well.
Then when the drill or tap breaks I get out my Rescue bit and drill them out thats a last resort that bit is a monster find them online or Snap-On truck. http://store.theoriginalrescuebit.com/RescueBits/
(notice I didn't get the welder out on a flush broken bolt? there is a time but not now ;) ) hth :thumbsup:
/ YM336D - Started knocking loud while tilling #234
One more on this Hi-Jack.
Looked after i posted. The bolt is actually 1/16 or so broke in the head, so i have nothing to weld too. Plus its an Al head i think, pretty sure i just dont remember and havent paid that close attention, if i weld it, im not that good on this type stuff and i will probly burn a hole in the head!!!!
Im going the route of hoping i get the center punched well and steping it up a bit at the time then try a easy out. I do like the idea of cross cutting a slot in it. I can then use an impact screw driver and hope that frees it!!
/ YM336D - Started knocking loud while tilling #235
Car Doc thanks for that list! I learned a lot.
Not a professional mechanic here, it's been a year since I had to replace a stud. (photo) (post - 'that wasn't supposed to break'). One tip I read on here (from Soundguy??) suggested heat the area around the stud gently to expand it away from the stud, then let it suck paraffin or PB Blaster etc down into the threads as it cools. Disclaimer: I haven't tried this. Drilling clear though to get lube below the stud sounds like a better idea.
/ YM336D - Started knocking loud while tilling #236
Then when the drill or tap breaks I get out my Rescue bit and drill them out thats a last resort that bit is a monster find them online or Snap-On truck. 1/8" x 3" Double Ended Rescue Bit - The Original Rescue Bit Store
Lets modify 2 & 3 a bit......
Learn how to offhand sharpen twist drills and relieve the webs. That goes a long way toward drilling holes in anything, actually using up a dtill bit instead of buying new ones, and, a properly sharpened twist drill with relieved webs usuall drills easily and straight....
Secondly, forget the 'Cobalt' drill bits. Bright HSS is just as tough as M42 Cobalt in most instances except when drilling old high carbon studs that have become hard from thousands of heat/cool cycles.
Get yourself a couple Die Reclaim drills from solid micrograin tungsten carbide.
MA Ford makes them as well as others. They are quite capable of drilling glass, hardened steel, armor plate, heat treated HSS, anything very hard and brittle. They are usually 2 straight flutes (no twist) and the recommended lubricant is water.
I turned the technicians on to them at the shop where it was a nightmare to drill the broken exhaust studs out of a 3406 Cat block. They were going through drills like water. Not any more.
/ YM336D - Started knocking loud while tilling #237
To take this further on a tangent, I spent literally all afternoon trying to drill two holes. One was a 1/4" hole through a hydraulic pump shaft, and the other was a 1/2" hole through mild steel. I broke every bit I have (7 or 8) in the 1/4" range.
Next, I ruined a pair of 18 dollar carbide burrs in my die grinder, and wore out a grinding burr to finally finish a 1/2" deep quarter-inch diameter hole. After wearing myself out and breaking my last pilot bit trying to drill a half-inch hole through mild steel, I gave up and decided I would weld the joint instead. So, I've got some nice spatter marks and burns through my jeans and skin to show for that.
The moral of the story is to learn how to drill holes and sharpen bits, and to not try difficult projects at my house; it gets too expensive! :laughing:
/ YM336D - Started knocking loud while tilling #238
Word of caution when drilling all the way through a stud bolt. It could likely be bottomed out and you could drill right on through the block or whatever the stud is screwed into. Unlikely senerio but something to think about.
/ YM336D - Started knocking loud while tilling #239
dtill bit????
New tool??:thumbsup:
Must be used for the dtill??
Glass houses.......just saying.
/ YM336D - Started knocking loud while tilling #240
I was asked for a few tips so I provided my method that works for me so use some or not its you guys prerogative you got what you paid for. :thumbsup:
Also I have a drill doctor and really dont like how it works on small bits so on the size studs I run into me sharpening my bits rather than buy new makes no sense new works good my sharpening ability on small ones is lacking.
btw 5030 can you provide a link I dont know what that is? "Get yourself a couple Die Reclaim drills from solid micrograin tungsten carbide."
2014 F-150 STX (A56438)
2014 F-150 STX...
2024 AGT INDUSTRIAL  H13R (A60736)
2024 AGT...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
CFG Industrial 680 QA Hydraulic Hummer (A60463)
CFG Industrial 680...
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
