YM240D Lift Arm Help
/ YM240D Lift Arm Help #1
emclark
I have owned a YM240D 2 cyl. diesel tractor since 1990.
In the past year or so I have noticed difficulty with the lift arm working properly. It has gotten to the point where it will hardly lift its own weight just a few inches.
I have changed the hydraulic fluid & cleand the filter but still no change.
I can hear the sound of hydraulic fluid when the lift arm is actuated.
If any member has has any suggestions as to what may be the problem & even more importantly how I might go about repairing the problem.
Thank you,
emclark_409
/ YM240D Lift Arm Help #2
My YM2000 is very close to your 240, I had a problem with the push rod on the control valve assembly. Under the seat there is a spring that connects to the feed back lever, when the control lever is moved to raise or lower the TPH the feed back lever moves the push rod. My push rod was stuck, a spray of WD-40 and a couple of taps on the back side of the feed back lever with a small hammer. It started to work fine, couple days later the seal around the push rod showed signs of a leak.
Replaced the seal and still working great.
Hope this helps
Thank you very much Alabama Kid for your suggestion.
I will try what you suggested tommorow when I can see a little better.
eclark
/ YM240D Lift Arm Help #4
Can we assume the hydraulic stop valve down by the floor has not been partially closed?
/ YM240D Lift Arm Help #5
where in al. are you ? /forums/images/graemlins/smile.gif
/ YM240D Lift Arm Help #6
</font><font color="blue" class="small">( owned a YM240D 2 cyl. diesel tractor since 1990. -emclark )</font>
So far as I know you are the first long-term YM240 owner to participate here.
If you don't mind - could you list any significant repairs your tractor has needed since it was new?
Thanks!
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
378908 (A61166)
378908 (A61166)
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2017 Ford Transit 250 Cargo Van (A61573)
2017 Ford Transit...
