YM226D Pwer Steering Unit
/ YM226D Pwer Steering Unit #1
DrewYM226D
Western Pennsylvania - Near Pittsburgh
YM226D, Cub Lo-Boy 154
Hello, I am a new member but I've been reading posts for some time. My YM226D has a power steering unit and I know these were not standard. The valve has a small hole or crack. I'm not sure exactly since the guy I bought it from had some kind or gunky-goo over the spot to slow the leak. It looks like the valve is aluminum and it has "PH-5001" marked on the side. Does anyone know if this is a Yanmar or other after market unit? Anyone think it can be repaired? Thanks, I appreciate the help.
/ YM226D Pwer Steering Unit #2
can you post a picture of the area ?
/ YM226D Pwer Steering Unit #4
Welcome Drew,
I think you'll find some pretty good parts support up in that area.
Bruce
/ YM226D Pwer Steering Unit #5
Perhaps the easiest way to repair it would be to run to the parts store and pick up some new gunky-goo? /forums/images/graemlins/tongue.gif
/ YM226D Pwer Steering Unit #6
Depending on where it is in the casting or what material it is , there are lots of ways to fix a problem. More info please........
/ YM226D Pwer Steering Unit #7
I don't know if it is a Yanmar unit or not. A couple styles were used., but parts aren't available. A do have a complete Yanmar powersteering assembly . If it is disassembled it may be possible to have it welded.
/ YM226D Pwer Steering Unit #8
I have repaired many of those PH units, there is two O-rings inside that need to be replaced. They are difficult to get to, but at least it is not expensive to do.
/ YM226D Pwer Steering Unit #9
Len;
Will the power steering assembly you mentioned for the 226 fit the 1820D you sold me?
If so what is the cost of the unit uninstalled.
Tom Hosack
OK, here's a pic that shows the unit. The little piece at the top that shines is where the red gunky-goo is. I hope this picture helps. Thanks again. You guys are great!
Caterpillar C18 Industrial Diesel Engine - Serial N8F01109 - Arrangement 385-7728 - Pump Takeout (A63689)
Caterpillar C18...
ROUND BALE HAY RING (A63291)
ROUND BALE HAY...
2014 INTERNATIONAL LF687 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2014 INTERNATIONAL...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
Caterpillar 3126 Engine Service and Parts Manual (A63117)
Caterpillar 3126...
