YM226D Pwer Steering Unit
/ YM226D Pwer Steering Unit #1
DrewYM226D
Western Pennsylvania - Near Pittsburgh
YM226D, Cub Lo-Boy 154
Hello, I am a new member but I've been reading posts for some time. My YM226D has a power steering unit and I know these were not standard. The valve has a small hole or crack. I'm not sure exactly since the guy I bought it from had some kind or gunky-goo over the spot to slow the leak. It looks like the valve is aluminum and it has "PH-5001" marked on the side. Does anyone know if this is a Yanmar or other after market unit? Anyone think it can be repaired? Thanks, I appreciate the help.
/ YM226D Pwer Steering Unit #2
can you post a picture of the area ?
/ YM226D Pwer Steering Unit #4
Welcome Drew,
I think you'll find some pretty good parts support up in that area.
Bruce
/ YM226D Pwer Steering Unit #5
Perhaps the easiest way to repair it would be to run to the parts store and pick up some new gunky-goo? /forums/images/graemlins/tongue.gif
/ YM226D Pwer Steering Unit #6
Depending on where it is in the casting or what material it is , there are lots of ways to fix a problem. More info please........
/ YM226D Pwer Steering Unit #7
I don't know if it is a Yanmar unit or not. A couple styles were used., but parts aren't available. A do have a complete Yanmar powersteering assembly . If it is disassembled it may be possible to have it welded.
/ YM226D Pwer Steering Unit #8
I have repaired many of those PH units, there is two O-rings inside that need to be replaced. They are difficult to get to, but at least it is not expensive to do.
/ YM226D Pwer Steering Unit #9
Len;
Will the power steering assembly you mentioned for the 226 fit the 1820D you sold me?
If so what is the cost of the unit uninstalled.
Tom Hosack
OK, here's a pic that shows the unit. The little piece at the top that shines is where the red gunky-goo is. I hope this picture helps. Thanks again. You guys are great!
2016 FORD EXPLORER SUV (A67737)
2016 FORD EXPLORER...
CAT 345CL NEW Track Chains (A68134)
CAT 345CL NEW...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A64557)
2022 21ft Scout...
2012 Ford F-250 Crew Cab Pickup Truck (A64556)
2012 Ford F-250...
2007 PETERBILT 335 SERVICE/LUBE TRUCK (INOPERABLE (A67714)
2007 PETERBILT 335...
Unused 2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
Unused 2022 WIFO...
