YM226D Pwer Steering Unit
/ YM226D Pwer Steering Unit #1
DrewYM226D
Western Pennsylvania - Near Pittsburgh
YM226D, Cub Lo-Boy 154
Hello, I am a new member but I've been reading posts for some time. My YM226D has a power steering unit and I know these were not standard. The valve has a small hole or crack. I'm not sure exactly since the guy I bought it from had some kind or gunky-goo over the spot to slow the leak. It looks like the valve is aluminum and it has "PH-5001" marked on the side. Does anyone know if this is a Yanmar or other after market unit? Anyone think it can be repaired? Thanks, I appreciate the help.
/ YM226D Pwer Steering Unit #2
can you post a picture of the area ?
/ YM226D Pwer Steering Unit #4
Welcome Drew,
I think you'll find some pretty good parts support up in that area.
Bruce
/ YM226D Pwer Steering Unit #5
Perhaps the easiest way to repair it would be to run to the parts store and pick up some new gunky-goo? /forums/images/graemlins/tongue.gif
/ YM226D Pwer Steering Unit #6
Depending on where it is in the casting or what material it is , there are lots of ways to fix a problem. More info please........
/ YM226D Pwer Steering Unit #7
I don't know if it is a Yanmar unit or not. A couple styles were used., but parts aren't available. A do have a complete Yanmar powersteering assembly . If it is disassembled it may be possible to have it welded.
/ YM226D Pwer Steering Unit #8
I have repaired many of those PH units, there is two O-rings inside that need to be replaced. They are difficult to get to, but at least it is not expensive to do.
/ YM226D Pwer Steering Unit #9
Len;
Will the power steering assembly you mentioned for the 226 fit the 1820D you sold me?
If so what is the cost of the unit uninstalled.
Tom Hosack
OK, here's a pic that shows the unit. The little piece at the top that shines is where the red gunky-goo is. I hope this picture helps. Thanks again. You guys are great!
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
Year: 2016 Make: Nissan Model: Pathfinder Vehicle Type: Multipurpose Vehicle (MPV) Mileage: (A66738)
Year: 2016 Make...
MechMaxx Grinder Betsco Flail mower
MechMaxx Grinder...
2018 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
3pt 14' Field Cultivator (A64912)
3pt 14' Field...
2012 FORD FOCUS SEL (A64280)
2012 FORD FOCUS...
