Ym1600 (can of worms)
   / Ym1600 (can of worms) #21
... thats when i dropped the pan and saw what my $1500 really got me. anyways, im just trying to make lemonade here.
I've won more gambles like that than lost. Net positive overall. (example. $25 for both!) But sometimes abandoning a project is the best solution.
Maybe part it out? That could recover most of $1,500. Looks to me that restoring this could be more expensive than replacing it. Is the rest of the tractor worth putting money into just the engine?
   / Ym1600 (can of worms) #22
The 2TR16 also has a Marine 2GM20 sibling that is fully interchangeable. It may even be the same engine, just the engine ID plate is changed. Over in the boating forum, someone owns a boat that had the tractor engine swapped in.
Yanmar 2tr16 - Cruisers & Sailing Forums
Here is a fully restored 2GM20 engine for $1,400
Yanmar 2GM20 16hp Marine Diesel Engine Package - Calvins Marine
This is a rare engine manual. With it you can determine what engines can swap into your machine.
Pay attention to items that compare to the 2TR16.
  • YANMAR ENGINE 2TR15 2TR16 2TR17 2TR19 2TR20 2TR20C.pdf
   / Ym1600 (can of worms) #23
Now, the 2TR16 has a direct sibling engine in series, it might be a perfect drop in. 2TR19.
This manual hints that the liners are different and the block is the SAME.
Piston and rings are different, but the crank, connection rods, and such are all the same.
This way, if you can not find a 2TR16 engine replacement and a 2TR19 is available, it should work.
Then change the decals from YM1600 to YM1900. (y)
These are small files I can add here. However, most manuals are too large to add to TBN, so the YTOG hosts them all.
  • YANMAR 2TR16 2TR19 PARTS MANUAL YP7302-07.pdf
   / Ym1600 (can of worms) #24
2GM20 is the marine version of YM2000 (2TR20) with different manifolds, water circulation, etc on it. And I think a windup or motorcycle kick starter secondary starting system for reliability in an offshore small commercial fishing boat.
But I expect a marine takeout could be just because the owner wanted to repower, or could be as bad as this engine - because it likely has been in service since the late 70's.
Yanmar's major emphasis is marine, I expect the marine versions outnumber the tractors.
   / Ym1600 (can of worms) #25
I just added the 2TR16/2TR19 engine parts list. The two engines can be swapped with one another.
   / Ym1600 (can of worms) #26
As soon as I fired up my YM240 my cousin said he recognized that clatter. Same as the small commercial fishing boat he was crew on in Alaska one summer.
   / Ym1600 (can of worms) #27
Just had my 2000 out for first full mow of the season. Bought from a UTDA dealer 2008. ASIS. Org. Gladly gave him the asking price.2800$ In the high 900tach, hrs that I put on it! Had to repair/Rebuild the starter. Not much to a rebuild on that tractor or cost. Shop to split my ford was only 1200$.New 2 stage clutch pressure plate and had to repair the shifter. It has a loader on it also. Your only looking at a few hundred dollars in parts and your time. From the posts and replies I don't think that to be a problem. No busted block your most likely good. Ever heard the term Turn a Crank? Repair the crank shaft! Not hard to do. Worst case most likely. Like to see the damage to crank shaft! Pics. My of YM2000 then and now all Org.. Gladly repair/rebuild this one if I had to. If it's repairable busted block Etc..
   / Ym1600 (can of worms) #28
1400 bucks for a replacement engine seems like a good deal. There would be shipping of course unless you could pick it up yourself. You tractor in good running condition would be worth more than 3 grand. Just look online to see.
Eric
   / Ym1600 (can of worms) #29
I mis-spoke above. 2QM-20 marine diesel, is the marine equivalent of the 2TR-20 (YM2000) engine.
From an experienced person in a boating forum:
Google shows several listed for sale in the boating world.
Another application of the basic engine was ThermoKing semitrailer reefer units, 40 years ago. That might be the cheapest source for a rebuildable core.
   / Ym1600 (can of worms) #30
For future reference if that site ever goes away.
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
*Selling at Royal Auction Zephyrhills, FL Location* 12 (A59230)
*Selling at Royal...
2002 International 9200i Truck (A56438)
2002 International...
25ft Barge Boat (A56859)
25ft Barge Boat...
