Ym1600 (can of worms)
   / Ym1600 (can of worms) #31
I mis-spoke above. 2QM-20 marine diesel, is the marine equivalent of the 2TR-20 (YM2000) engine.
From an experienced person in a boating forum:
Google shows several listed for sale in the boating world.
Another application of the basic engine was ThermoKing semitrailer reefer units, 40 years ago. That might be the cheapest source for a rebuildable core.
There is a 2QM15 and has hits for the 2TR15 and 2TR16 engines. Yanmar supports these engines even today.
Found the service manual for it here, all in English.
https://j30.us/files/2qm15_servicemanual.pdf
Here is the Parts Manual,
With the rear mounting flange removed, it 'could' mount to our YM tractors.
It would be nice to find an engine to repower keeping the YM1600 going via a marine diesel or a 2TR19 upgrading the YM1600 to a YM1900.
   / Ym1600 (can of worms) #32
If you can't find the "correct" motor, how much similarity is there in engine block dimensions between the 2TR13 class and 2TR16, 17, 18, 19?
   / Ym1600 (can of worms) #33
I had added the manuals a few posts back. The 2TR16 and 2TR19 are swapable.
The 2TR13 nor 2TR15 are too much work or will not swap in due to different bell housing interface differences.
   / Ym1600 (can of worms) #34
i bought it from a guy who said he ran it out of fuel and couldnt get it to start. it came with a brushhog and 4 new briefcase weights. so, after priming it and still not getting it to fire i covered it in a wool blanket and set the heat gun on it (its like 25degrees in the shop). after that i was able to get it to cold start for literally only a couple revolutions before it made an atrocious squeal and dead stopped. i got it to do that a few times then figured i had bigger problems. thats when i dropped the pan and saw what my $1500 really got me. anyways, im just trying to make lemonade here.
How much do you "need" this tractor? The way I always look at the economics of fixing vs replacing something is: what would it cost to buy a new/similar one?
   / Ym1600 (can of worms) #35
Exactly. One reason why we post replies of possible engine swaps or links to a new refurbished head with all the hardware too.
It is possible to find another YM1600 or YM1900 tractor. Then use the broken YM1600 as a spare parts machine. Indeed it is best to look over every single option before venturing out blindly to solve the problem.
The cost of full overhaul the engine or find a full replacement tractor is a strong choice to consider.
There are 4 FB Market Place YM1900 tractors listed across the USA right now.
Several YM1600 too,
   / Ym1600 (can of worms) #36
Crank shaft?...... Not that bad is my guess. There is a oversized main bearing also. You may have to turn it! Tell tale!!...... How about a pic.. ?
   / Ym1600 (can of worms) #37
Looking into this the YM1600 Crankshaft . The same is used in the 195,240,1600,1700,1900,,2000,2210....... Parts problem? Doubtful LOL;;;
   / Ym1600 (can of worms) #38
Reading along and looking at the pictures of the not running engine, I'd say the original owner put his oil changes on a very low priority bases as in never changed it.. What a cruddy, sludge loaded up motor.
   / Ym1600 (can of worms) #39
Read Post #5 and starting fluid!
2018 Bandit 15XP Wood Chipper (A57453)
2018 Bandit 15XP...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
21' 20" Aluminum Corrugated Pipe (A57149)
21' 20" Aluminum...
Online Buyers Premium (A55272)
Online Buyers...
Giyi Pile Hammer (A57149)
Giyi Pile Hammer...
2013 Vermeer BC1000XL Towable Brush Chipper (A56857)
2013 Vermeer...
