PT AL-629 ( can it be done ? )
   / PT AL-629 ( can it be done ? ) #81
KentT said:
But, the two wheel motors in a series circuit where the pump only puts out 1500 PSI (your propositition) would only be using 750 PSI each -- 750 PSI at the front motor, and 750 PSI at the rear motor... that's where you're misunderstanding lies.
I understand your point.
Perhaps you do not understand mine--Without specs or data there is nothing to anchor the analysis. What the calculators show is that doubling either pressure or flow doubles horsepower. But--so far as I know there is nothing to anchor either pressure or flow produced in the drive circuit. We both are just guessing.
That guessing can be resolved one of two ways--get specs or get measurements.
   / PT AL-629 ( can it be done ? ) #82
But, we can reverse engineer an approximate gpm flow based upon the known specs of the White wheel motor and the speed the PT will travel. With 23" tires, it takes 14.61 RPM for the PT to go 1 MPH. It is rated for 8 MPH plus, and I've heard estimates of 10 MPH with these old wheel motors. 8 MPH would require 116 RPM. 8 MPH would require a flow of more than 6 gpm, at any rated PSI, according to the motor's published performance specs. 10 MPH would require 8 gpm at 500 - 750 PSI. So, though we can't reverse engineer a "hard number" we can get a range -- the tram pump is definitely capable of putting out between 12 - 16 gpm at 1000-1500 PSI (twice the PSI available to any wheel motor because of the series circuit.) We can anchor that much....
Meanwhile, we have the hard performance data to compare one wheel motor to another. For example, replacing the White RS series 12.5ci wheel motor with the Char-Lynn S series 18.2ci wheel motor will increase the torque by 61% at 4 gpm flow at 1000 PSI or 56.5% at 6 gpm at 1000 PSI. Comparing the performance data of the two motors, the least increase in torque is 39% -- from from 1809 PSI to 2897 PSI at 2 gpm and 1000 PSI. Even a 39% increase is significant....
And for those of us who need more torque, it is inviting. Even if my tram pump isn't operating at 100% efficiency, a 39% increase in the amount of torque currently available (whatever that may be) -- is still significant to me....
   / PT AL-629 ( can it be done ? ) #83
I would love to post my honest thoughts about- where all this over analytical, redundant, MIT BS is headed with regards to increasing the wheel torque on the 180, 422, or 425, but I will restrain myself and just say- HAT'S OFF TO JOHARAL for taking the time to just upgrade to a larger displacement wheel motor that operates within the restaints of the OEM engine, pump etc. without rewriting the book on hydraulic's 101
   / PT AL-629 ( can it be done ? ) #84
KentT said:
But, the two wheel motors in a series circuit where the pump only puts out 1500 PSI (your propositition) would only be using 750 PSI each -- 750 PSI at the front motor, and 750 PSI at the rear motor... that's where you're misunderstanding lies. For a wheelmotor in a series circuit to produce the power that corresponds to 1500 PSI, the pump would have to output 3000 PSI.
You sure about that? Think of pressurizing a garden hose. Anywhere along the line the PSI is about the same until you open a valve at the other end. Then the pressure drops out.
So, if you drive your PT up against an imovable object and then step on the treadle, before the tires spin or a relief valve kicks in, I would think you would get the same PSI between the pump and the first motor and probably between the first and second motors, then dropping off dramatically after the second motor as it has free return to the pump. The PSI would not be divided in a series circuit, nor would the GPM.
   / PT AL-629 ( can it be done ? ) #85
Well, it never hurts to learn how something works inside and out. It is a great brain exercise and keeps us young.
HEY! I think I have just proved that owning a PT is the fountain of youth! :D:D:D:D:D:D:D:D:D
   / PT AL-629 ( can it be done ? ) #86
Yup, I'm sure. It helps to think of it from the perspective that it is the wheel motor that is causing the PSI, not the pump. The resistance of each wheel to turning adds 1/2 the pressure to the circuit (in a "100% efficient system" where you're not considering the resistance of hoses, fittings, etc.). The two parallel circuits on the PT have the same input pressure to the front wheel motor on each side. But, each wheel motor in that circuit operates at 1/2 the pressure that the circuit contains. The wheel motor in a series circuit operates on delta PSI -- the difference in pressure between its input and output ports. The wheel motor in front must be able to "contain" the full pressure, but because it has the back-pressure of the rear motor on its output port it can only produce the power of the input port pressure less the output port pressure.
   / PT AL-629 ( can it be done ? ) #87
MossRoad said:
... I would think you would get the same PSI between the pump and the first motor and probably between the first and second motors, then dropping off dramatically after the second motor as it has free return to the pump. The PSI would not be divided in a series circuit, nor would the GPM.
Think of it, MR... Why would the pressure drop off after the second wheel motor and not drop off after the first? Half of it drops at the first and the remaining half drops at the second... If the motor had the same pressure on on the input port and the output port, it wouldn't move at all.
It also helps to think of it as "load" on the system instead of pressure. Half the load comes from the front wheel motor and half from the rear one.
   / PT AL-629 ( can it be done ? ) #88
Well, if the first wheel motor had no resistance and the second one was locked against an imovable object, the first one would just be rolling with the flow and the second one would be providing all the resistance to the flow.
   / PT AL-629 ( can it be done ? ) #89
But, flow cannot take place except across a pressure differential... if the pressure was the same on both ports, no flow would be taking place. So, the first one wouldn't move at all.
Added: I wanted to add that if you are ever pushing against something with a PT bucket, for example, and the front tires start spinning faster than the rear because of down-pressure lifting them up, the difference in speed between the front and rear tires would be caused by the leakage past the rear wheel motors. If you'll notice, those tires still spin slowly when they do spin -- in relation to the treadlle position and throttle setting. But, if the wheels were plumbed parallel (the concept behind the Stray mod) the front wheels would get almost all the flow and they'd spin like mad...
   / PT AL-629 ( can it be done ? ) #90
:D :D :D Sorry if I'm redundant. I'm ****ytical by nature and a systems requirements ****yst by training, so I do tend to over-****yze things. My wife says that's only partially correct -- that I'm just ****... :eek:
That's how I learn, though, and how I apply that learning to new situations -- I try to understand the "theory of operation" behind something. In this case, this wheel motor upgrade will likely cost about 25% of what I originally paid for my PT and the 5 attachments that came with it. I could likely buy most any new attachment available (and perhaps two) for the price of this upgrade alone, by the time it's done, so it is significant -- at least to me...
2018 Knap Heide KTEC88-McCoy24.5 SP Flatbed (A58216)
2018 Knap Heide...
UNUSED FUTURE PG72 72" HYD PLATE GRABBER (A58376)
UNUSED FUTURE PG72...
2025 BK56 Backhoe Skid Steer Attachment (A56857)
2025 BK56 Backhoe...
UNUSED FUTURE MPR42 42" HYD MINI POWER RAKE (A58376)
UNUSED FUTURE...
LOT: Assortment of PVC Pipe (A59076)
LOT: Assortment of...
Philadelphia Tram Rail (PTR) 60 inch Cardboard Recycling Baler (A59213)
Philadelphia Tram...
