YM 336 Engine Issue
/ YM 336 Engine Issue #11
If you are going to rebuild it I would definitely invest in a service manual, and pay special attention as to why #1 rod bearing only lasted 3 months, (if I understand correctly).
/ YM 336 Engine Issue #12
The crank can usually be welded back up and turned down to "stock" size, you will have to remove it tho. As to whether this is cost effective or not will depend on you and the cost and availabilty of a new one. You probably need to resize those rod ends too.
I agree with Norm tho, you need to find out why it's so bad (ie:did you have any oil pressure?) Although you wouldn't with that much air in the bearings. :D
You need to go thru the entire engine very carefully, there's going to be metal in every oil passage and thruout the engine.
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
iDrive TDS-2010H...
John Deere 5075E (A53317)
John Deere 5075E...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2CJ453403 (A61165)
2012 International...
2011 John Deere 995 (A60462)
2011 John Deere...
