Yanmar YM 145 ???
/ Yanmar YM 145 ??? #1
Gunfighter
West Michigan
JD 790, Steiner 230, IH 340U, Farmall Super C, Farmall C, IH Cub Cadet, Wheel Horse 8.75
I'm looking at a 2 cyl. diesel, Yanmar YM 146, 3 sp trans with power shift.
Think it has hydraulics an maybe a differential lock, not sure about that...
I would appreciate any information on this tractor. What year
made an what would be a decent price in very good condition.
The only equipment it has is a belly mower... I would like a
snow blade for it, providing it has a differential lock..
Oh, last but not least, how hard to find are parts for this tractor???
Richard
West Michigan
/ Yanmar YM 145 ??? #2
Hi,
I've got a 147, which I'm guessing is newer than the 146. Mine is a 1987 model. This is a USA Model and not a grey so it will bring a higher price than the greys. I have not needed many parts, but none have been a problem. It has the diff lock, a lever that you step on to the right of the seat. Has a flat round end that you push with your heel. Price, depends on condition How many hours? Maintence, How beat up is it? What size mower, Yanmar mower? Turf tires or Ag. My 147 had turf and I have also bought a set of rims for Ags. A two wheel drive with Turf tires has very little traction for using a box blade. Mine only weighs around 1000-1100 lbs. For mowing, spraying, light brush hogging, it makes a good little tractor. If you have plan to do dirt work 4wd is a must.
I would guess $2,000 to 5,000 depending on hours and condition. VGC, I would guess around $4000. Others may have a better idea on price. I only see maybe 1-2 USA yanmars around here a year.
/ Yanmar YM 145 ???
I stopped by the dealer with Yanmar 146, they are asking
$2295.00. The tractor has turf tires, is 2WD, does not have
3 pt hitch...
The paint look like original, the tractor look in excellent condition
The hour meter shows 791 hours if it can be believed...
I'm personally not looking for a tractor but was thinking to get it
for my son... He's got couple acres of grass to cut an a long
400 ft driveway to maintain an snow plow...
I heard what you said about the 2WD an ground work but was
wondering with if the differential lock would off set not having 4WD...
RJK Sr.
West Michigan
/ Yanmar YM 145 ??? #4
Gunfighter,
If its a dealer they should provide you with a 3 pt conversion kit for a little extra. Also I don't recall ever seeing a Yanmar w/o differential lock.
For what some people pay for garden tractors, the YM146 is a better deal. The diesel power and longevity plus combination of implements make it very suitable for a couple of acres.
There is no substitute for 4 wheel drive though.
Good luck, Mark
/ Yanmar YM 145 ??? #5
My first tractor was a Bolens G152. A little 3 cylinder 15hp diesel with wide turf tires and only 2 wd drive. I done a lot of dirt moving with that tractor and a 4 ft landscape box. There is an old say, well maybe not that old, "Any tractor is better than no tractor". The diff lock won't offset the lack of 4 wheel drive. The funny thing is that when you don't have certain things, you learn to work around them. For that price I would not hesitate to get it for him. No it won't be able to do everything but it is a start.
/ Yanmar YM 145 ??? #6
A three point would be a must for me. Does it have a 540 PTO and just needs the linkage/bars for the three pt? I think I have seen pictures of a 135 or 145 from the pictures it looks more along the lines of a lawn/garden tractor? The 147 has a 3 pt and 540 PTO.
There is or was a Yanmar on Ebay that had a blade on the front and hydraulic cylinders for lift and angle. Might give you some ideas.
You will be amazed at the difference in fuel usaged between the little Yanmar and a similiar size Briggs and Stratton. I don't think the diff lock is a substitute for 4wd, but as Tractors4U said and I agree 100% a little tractor is better than no tractor. I don't see how you could go wrong price wise it is about the same as a low end new lawn/garden tractor.
/ Yanmar YM 145 ??? #7
Just wanted to add that if your son is mechanically inclined it won't take long to improvise to his environment. Have to agree completely with Brent....If you've never had all the options, you never miss them.
Personally, I think considering or providing him with a tractor is very touching, and probably the perfect addition to his property.
Mark
/ Yanmar YM 145 ??? #8
Do a search on "yanmar" on ebay. There is a 169D with a snowplow on the front. Has about 2days left on the auction. Would give you an idea for a front blade.
/ Yanmar YM 145 ??? #9
sorry to go off topic, but since that 169d was mentioned... does anyone know much/anything about that model? 18HP right? And, gunfighter, I would only think that your son would be thrilled to receive a tractor from you. And, speaking from experience, what you don't have, you don't miss, until a friend gets it!! /forums/images/graemlins/smile.gif Thanks...
/ Yanmar YM 145 ??? #10
16hp gross on the 169. Late 80's USA model.
/ Yanmar YM 145 ??? #11
The YM146 was identical to the later GT14, which is what I have. I'm working on restoring it. I have had to do a lot of work to it to restore it, and I'm not done yet. I have not found a single part that I can't get yet, but I have been waiting a LOOONG time for some parts to come in from Japan. It's a good little tractor, runs well, sounds like an old John Deere 2cyl at idle. Won't be that good at pushing snow, but they did make a snowblower for it. I actually saw one for sale on ebay this winter. I ended up buying a 48" Wheelhorse snowblower that I'll be attaching to it. The tractor has 14 horsepower at 2600rpm, and came with a 48" deck standard. The PTO attachement for the rear is still available, but i've been told the 3pt kit is no longer available. It wouldn't be that hard to fab a kit if you're into fabrication though. That's what I'll be doing. I bought mine mainly as a mower tractor, since I have a much larger Oliver tractor for bucket and plowing chores. My opinion is that this is a great mower tractor, but without the 4wd and with the turf tires, it's not a real good snowplow tractor. I bought mine in Wayland Michigan (probably somewhere near you) at Stamm's equipment on a 50% off sale. It was under a grand, but it has needed some real work. Good thing I'm handy with a welder. I've seen nice GT14/YM146 in Michigan for $2500-5000. Mine's the sorriest one I looked at. I'm a sucker for the underdog I guess. Feel free to ask me any questions, I'm a mechanical engineer who likes to tinker on diesels and fabricate parts, so If I ever get the thing finished, I'll post pics.
/ Yanmar YM 145 ??? #12
86turbodsl, sounds like quite a project. I think I might speak for others as well, but pics of work in progress and a dialog on how the restoration is going would be pretty cool to see. Of course, if you have the time! Good luck -arthr
/ Yanmar YM 145 ??? #13
Heh, time to work on it is hard to come by, much less make webpages about it, but I'll try and post here at milestones... /forums/images/graemlins/smile.gif
Still waiting on brakes and a few other parts. It hasn't moved in 6 months.
/ Yanmar YM 145 ???
Not sure if the son wants the little tractor. I gave him a Cub Cadet 125 Hydro with mower deck an snow blower. It's a great mowing tractor an the snow blower can send snow into the next county but his drive is 350 feet all down hill. It works good going down but has a lot of difficulty getting back up. He thinks even with the differential lock, the Yanmar might not work much better. Unfortunately I think he maybe right...
Going to give it some thought, but I may still get the Yanmar. I have a J.D. 790 which is a Yanmar, it's a tough little tractor, I don't think a guy can have to many tractor, now to convince the wife...
86turbodsl
If I end up getting the tractor, I'll be looking to pick your brain...
Richard
West Michigan.
/ Yanmar YM 145 ??? #15
With a little help, the Cadet may well do the job. I have 1400' of driveway. No hills but a few slopes that give some trouble. Last year I blew snow with a Case 220, 10 H.P. Hydrostat. With the tires loaded and chains on it I never got stuck. It worked like a charm but I felt that it was to much work for the old 10 horse, so this year I bought a YM195D. It's a great tractor but honestly not a lot better than the case as far as blowing snow goes.
/ Yanmar YM 145 ??? #16
How about differential lock and CHAINS!?
/ Yanmar YM 145 ???
Gary
Thanks for the e-bay tip, there was several picture that could be
helpful if I get the tractor...
Richard (ducksjunk)
Yes we tried chains but the tire are small on the Cub Cadet 125,
they have a tendency to dig in and can't climb out...
As for loading that size tire, don't think it matter. If my 250lb on
the seat an my son 170lb standing on the rear hitch doesn't help,
an extra 25lb per tire won't matter...
If the driveway was black top or concrete there would be no problem
but with a stone drive, you need to run skid shoes leaving a thin
layer of snow an it's this snow when packed that the chains dig into.
The depression is sometime no more then a inch but the little tires
can't climb out...
Richard
West Michigan...
/ Yanmar YM 145 ??? #19
"It works good going down but has a lot of difficulty getting back up. He thinks even with the differential lock, the Yanmar might not work much better."
I wouldn't attempt to use the differential lock to get up a 350' hill, or anything more than getting unstuck in a brief straight ahead shot. The lock is only a small pin that engages a gear and is easily sheared off, especially if you try to turn, and is a pretty extensive repair.
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
JOHN DEERE 460M SILAGE BALER (A63291)
JOHN DEERE 460M...
2024 Freightliner M2 106 Altec DM47B-TR Insulated Digger Derrick Truck (A61573)
2024 Freightliner...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
John Deere HX14 Rotary Cutter (A64047)
John Deere HX14...
11R22.5 ALUMINUM WHEELS AND TIRES (A63569)
11R22.5 ALUMINUM...
