yanmar tiller
/ yanmar tiller #1
Cajuncactus
I just bought a 48" yanmar tiller for my 1610d. I tried to install it and it seems too close to the rear tires and the top link seems too long. If any one has any ideas or pictures, that would be great. If I extend the lower area where the bottom pins hook up it seems like it will work. Thanks a bunch, R
/ yanmar tiller #2
The yanmar tillers do set very close to the rear tires. It should raise and lower without hitting the tires but will set very close.
I always spend an hour trying to get that thing connected up.
THe pto shaft is so short there is no room to get my american sized body down in there to hook things up.
/ yanmar tiller #3
You are going to need the original Yanmar 2-piece top link for use with those tillers. The majority of those grey market tillers will not allow the use of a normal toplink. If you try, the front of the tiller hits the tractors tires. Another option is adding brackets and moving the lower lift pins on the tiller about 6" forward. This will allow you to use a regular toplink. Of course you will also need a longer PTO shaft. Attached is a picture of a moded tiller.
/ yanmar tiller #5
Yanmar has a special center link that bolts to the tractor. This bracket moves the pivot point back 8-10 " and keeps it away from the wheels. I sold my yanmar a year ago, but kept the bracket and install it on my Kubota for tilling.
/ yanmar tiller
Thank you for all the repies, this is what I have planned to do. I picked up some flat steel today. Thanks again, R
/ yanmar tiller #8
Hey, thanks for that pic. I have one of these tillers too and hadn't tried to hook it up and use it yet cause I wasn't sure how to attach it. That really helps...........
/ yanmar tiller #9
In your photo what is the device on the pto shaft. Is it a thing like you use for a bushhog to let it freewheel. Also what should be the adjustment of the threaded shortarm link between the bracket mounted on the tractor and the tiller. thanks Paul
/ yanmar tiller #10
Here is picture of my 48" yanmar tiller connected to my 2015. Since I have a hydraulic top link, I modified the old one to about 11" between the centers of the overall lenght. Hope this helps.
/ yanmar tiller #11
</font><font color="blue" class="small">( In your photo what is the device on the pto shaft. Is it a thing like you use for a bushhog to let it freewheel. Also what should be the adjustment of the threaded shortarm link between the bracket mounted on the tractor and the tiller. thanks Paul )</font>
I have replaced that shaft with a new one since that picture was taken. The old shaft was a bit to short and when I tilled real deep it wanted to come apart on me. The yellow part you see in the picture is 1/2 of the protecive cover. If it was all there it would help keep you from getting wrapped up in the shaft should you have a momentary lapse in judgement and put you hand or arm near it. My new shaft has a protective cover on both ends.
/ yanmar tiller #12
RBEITZ where did you get your new shaft from for your tiller? I have the same problem when I am tilling my shaft likes to come apart.
/ yanmar tiller #13
Not to hijack this thread but does anyone know of a parts source for Yanmar tillers made in the USA. Mine is a 48"
model 1218, probably made by another maker. The serial number plate says made in the USA. My father bought it new, probably in the early 80s. I need new tines. It does not look at all like a gray tiller, more like a USA made job.
/ yanmar tiller #14
</font><font color="blue" class="small">( RBEITZ where did you get your new shaft from for your tiller? I have the same problem when I am tilling my shaft likes to come apart. )</font>
Sorry, to take so long to respond. I didn't see this post until today. I bought the new shaft from Buck at EFC.
http://www.efcconstruction.com/new_page_2.htm
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
2022 EZ-GO ELITE...
John Deere 1770 Planter (A63111)
John Deere 1770...
2016 TAKEUCHI TB240 EXCAVATOR (A64279)
2016 TAKEUCHI...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
