Yanmar Hydralics Problem
/ Yanmar Hydralics Problem #1
Pozman
I attached my Brushog today, rasied it with the hydraulics just enough to get it off the ground. The hog went all the way up and now it will not go down. The levers do not do a thing. Had to store it that way, put logs on end to support the hog.
Looked like there were some fluid on the hydaulics dipstick but did not appear to be much when I looked down the resevoir. Could it be that it is just low on fluid and not working so it stuck in the up position?
Used it last summer with no problems. This was the first time I was going to use it this season. Any input would be appreciated.
/ Yanmar Hydralics Problem #2
I don't know what model you have, but I think they all have a drop rate lever under the seat and a servicing valve down by the floor to hold the 3ph in the raised position for servicing. Have either been closed?
My inital thought was the valve under the seat, I turned it in both directions, it did not do a thing.
By the way, the model I have is a YM1702. I am baffled by this one.
/ Yanmar Hydralics Problem #4
If the 1702 is like the 1700 there is also a lever under the seat which controls the rate of drop for the 3 pt hitch. I may be all the way to the slow postion and could cause that as well. I accidentally did that to mine when I first got it.
/ Yanmar Hydralics Problem #5
Hey, Dude, I had same type problem. Take a look at my post history on 11/13/04 GrenAkrsFrmr. Mine was with a 1401D but i've been told most all hydro. systems are basicly the same, but word of warning, if there is a limit adjustment attached to your raise/lower control handle- don't mess with it.. I did==BIG mistake!!! When I finally had to take mine apart, the piston had been pushed all the way out of the bottom on internal cylender.
Good Luck to you.
GrenAksFrmr thanks for the input. Hopefully, I can get to this in the next couple of weeks. I let you know how things work out.
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
John Deere 5045E for sale
John Deere 5045E...
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
