Yanmar engine swap/compatibility
/ Yanmar engine swap/compatibility #1
millard762
yanmar 165D
I am kind of curious if anyone would know which 3 cylinder yanmar engine(s) could be swapped in place of the 2TR13A. I think it would be fun to find one of these old diesel engines and slowly rebuild myself and maybe add a small turbo on and have on hand and maybe swap in place of current engine. Thanks
/ Yanmar engine swap/compatibility #2
Bottom end Wet sleeve, (2TR13A) WS-75 155,165.1300.
/ Yanmar engine swap/compatibility #4
Elaborate about eng Block? that he can use ?
Engine block the same with which 3 cylinder model? I thought about a small turbo on my 2TR13A, but kinda decided against it
/ Yanmar engine swap/compatibility #7
From the 2TR family engine manual, the 2TR13 is not able to interchange with anything. It is, its own unique engine.
Most of these can interchange,
15-16-17-19-20-20C
and the 22-27 can only interchange amongst each other.
/ Yanmar engine swap/compatibility #8
Eng. blocks he can use. YM155 YM165 YM1300 uses the same wet sleeve which uses the same ENG. Block. Fredricks W-75 Wet Sleeve.
/ Yanmar engine swap/compatibility #9
What he wants to do is replace his 2cyl with a 3 cyl.
/ Yanmar engine swap/compatibility #10
His options pretty much. Not like a Ym2000 Ym2000B 2-3cyl. will bolt to the same transmission from what I could see.??
Thanks all
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
Case 1150G Dozer (A66285)
Case 1150G Dozer...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
25026SFL (A61569)
25026SFL (A61569)
