Yanmar engine swap/compatibility
/ Yanmar engine swap/compatibility #1
millard762
yanmar 165D
I am kind of curious if anyone would know which 3 cylinder yanmar engine(s) could be swapped in place of the 2TR13A. I think it would be fun to find one of these old diesel engines and slowly rebuild myself and maybe add a small turbo on and have on hand and maybe swap in place of current engine. Thanks
/ Yanmar engine swap/compatibility #2
Bottom end Wet sleeve, (2TR13A) WS-75 155,165.1300.
/ Yanmar engine swap/compatibility #4
Elaborate about eng Block? that he can use ?
Engine block the same with which 3 cylinder model? I thought about a small turbo on my 2TR13A, but kinda decided against it
/ Yanmar engine swap/compatibility #7
From the 2TR family engine manual, the 2TR13 is not able to interchange with anything. It is, its own unique engine.
Most of these can interchange,
15-16-17-19-20-20C
and the 22-27 can only interchange amongst each other.
/ Yanmar engine swap/compatibility #8
Eng. blocks he can use. YM155 YM165 YM1300 uses the same wet sleeve which uses the same ENG. Block. Fredricks W-75 Wet Sleeve.
/ Yanmar engine swap/compatibility #9
What he wants to do is replace his 2cyl with a 3 cyl.
/ Yanmar engine swap/compatibility #10
His options pretty much. Not like a Ym2000 Ym2000B 2-3cyl. will bolt to the same transmission from what I could see.??
Thanks all
Morbark Wood Chipper (A63118)
Morbark Wood...
5ft Tiller (A64047)
5ft Tiller (A64047)
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
2024 Blue Diamond Trencher (A63116)
2024 Blue Diamond...
24004SFL (A61574)
24004SFL (A61574)
Case Titan 3530 (A63118)
Case Titan 3530...
