Yanmar 240 Loader Hydraulic issue
/ Yanmar 240 Loader Hydraulic issue #61
I remember rs!.. Nice guy..
/ Yanmar 240 Loader Hydraulic issue #64
wow, I didn't think so!
/ Yanmar 240 Loader Hydraulic issue #65
Yup.
I all the time will leave a bucket up and the machine off to do something, then just yank on the spool to drop it when done.
There is some BIG part of this story we are not hearing. the simple lack of pump / pressure just means no more 'UP'. Down is free, up costs ya.
I have to agree,, If the pump is all that was wrong.. What kept the bucket from falling to the ground ??
Pump controls up, curl, dump but ,it should free fall if pump doesn't pump fluid
My bucket will fall with the engine off
/ Yanmar 240 Loader Hydraulic issue #66
I will always lower the bucket sometimes when the tractor is off. That is when i borrow a freinds that has a loader!!
/ Yanmar 240 Loader Hydraulic issue #67
when i'm not using it I lower all mine too.. but if I'm actually using it to lift something.. I leave it up. :)
Like lifting a bale and then backing something under it, etc.
/ Yanmar 240 Loader Hydraulic issue #70
https://groups.yahoo.com/neo/groups/yanmartractorownersgroup/conversations/messages
Yep, here's the original, probably has threads going back to 2002 when talking about TBN.
I see posts from R.S. and Leonard in that list. I wish both would share more of their knowledge here.
I still receive that list as email. But I haven't posted to it for years, after some spammer stole my my real name and email from there or another Yahoo group and used it for the 'Reply-To' in his spam. I received near 10,000 bounce messages from ISP's saying Addressee Unknown (every addressee was different!) and a few outraged replies from real people who emphatically and colorfully denied they wanted a remedy for ED. The one I remember was some lady saying she received the spam on her official State Bureau of Tourism email in Georgia or someplace where it seems young ladies don't talk about such things, but nevertheless she seemed to know a wide variety of related terms to express her opinion.
/ Yanmar 240 Loader Hydraulic issue #71
Yup, Leonard was decent folk. I had some cobbled stuff for an air cleaner and he helped me find parts.
It IS very peculiar that the levers could not release the pressure to lower the bucket, but now that the aux hydraulic pump is turning again the bucket operates normally, plus I am able to lower it to the ground with the engine running or not.
There is a bit of sticking on the way down some times, even under power so perhaps the cylinders need to be rebuilt or replaced as well.
It seems to be defying logic and gravity.
However I have learned since then, that time slows when there is less gravity so maybe there is a disturbance in the local gravity field causing this phenomenon :eek:
I should try it again after moving the tractor away from its usual parking spot :confused2:
/ Yanmar 240 Loader Hydraulic issue #73
are your lift cyls SA or DA?
Sorry for the long absence, many things going on but at least I resolved my Hydraulic issue and I wanted to circle back and close the loop.
Are you ready for this?
The key on the aux hydraulic pump shaft was missing, hence the PTO turned but not the shaft of the Hydraulic pump and so its no surprise that I had no hydraulic pressure to operate.
There is a screw that goes through the keyway to lock the key and shaft in place and I guess it got loose and the key worked its way out as it was not sheared but simply missing.
I don't like that design but in the end I simply replaced the key and used a better screw and its all operational again.
The problem was hard to diagnose because the Aux pump shaft was visibly turning but when I went around the to controls as soon as I tried to work the loader it would get a tiny bit of movment and then stop.
What was probably happening was the shaft would turn but as soon as some resistance was met in the pump I presume the Aux pump shaft would stop spinning and no further pressure developed.
I guess I learned a few things about the tractor along the way.
One of these days I'll have to address the leaking hydralic cylinders next. I go through 2, 5 gallon pails of Hydraulic fluid each year.
/ Yanmar 240 Loader Hydraulic issue #75
My that's some leak. I think if you fix it the savings in hydraulic oil will be recouped in a year or 2....
/ Yanmar 240 Loader Hydraulic issue #76
Rebuilding hydraulic cylinders is idiot simple. Take them apart and take the existing seals to a specialist hydraulic shop for replacements. Reassemble.
The only thing that might be difficult is the amount of force it takes to unscrew the end caps. My first repair was done by a professional shop, I saw he just used a giant pipe wrench to take off the end cap. Next time one leaked I bought a 36" pipe wrench and needed a cheater pipe on that. Tip - leave one end of the cylinder attached to the tractor so you have something to wrench against.
Even if you need to buy a specialty wrench for the end caps, you will be way ahead doing the work yourself. Study diagrams and instructions for the type of cylinders you have, then just do it. You can always take the cylinder in to a pro shop if you get to a point where you can't get any farther.
My first cylinder cost $165 for the pros to do it, next ones about $10 each to just buy the seals from the same shop.
Well thats good to know that its pretty simple job.
I guess I'll start with the 2 bucket curl cylinders to get my feet wet.
The built-in 3 point hydraulic seals need to be renewed as well since the 3pt leaks down fast and doesn't operate that well, even with the lock applied.
/ Yanmar 240 Loader Hydraulic issue #78
the question still remains of why the spool valves would not drop the loader when the machine was off. no pump needed for that to happen..??
True, that still does not make sense to me either as with the tractor off I believe I have been able to lower the FEL in the past.
I'll have to try that though to confirm, as it might be some kind of safety feature of the Hydraulic circuit to prevent movement with the tractor off and hydraulic pump off.
/ Yanmar 240 Loader Hydraulic issue #80
not on something this old and simple!!
1 PALLET OF JACK & IMPACT GUNS (A66091)
1 PALLET OF JACK &...
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
Komatsu PC220LC7 Thumb Jaw (A68134)
Komatsu PC220LC7...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
NEW HOLLAND T4020 TRACTOR (A65057)
NEW HOLLAND T4020...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
