Yanmar 240 Loader Hydraulic issue
/ Yanmar 240 Loader Hydraulic issue #21
op? how did the test go?
I'll take a look this weekend at the valve controls.
Had a number of failures last weekend, First the Tractor that I was using to grade a flat area for the shed (did the remainder work the box scraper), then I bought a Framing nail gun for the shed I'm building and the compressor had the main tank valve break, so nailing by hand, then the Jeep Wranglers battery was simply dead and I couldn't go anywhere until AAA came and replaced the battery.
So now that all those Murphy events are out of the way, I'm hoping my plans will go smoother now and I can figure out the Hydraulics quickly and get that shed built, although I'll have a sore hammer arm this time around I guess till the compressor part arrives.
Seems I always end up doing these projects when its in the 90's and 100's....and that tends to slow the work pace.
I guess the above was an update, rant, catharsis...I feel better now, and appreciate all the guidance on the Tractor issue.
I'll post an update when I've taken stuff apart to see whats the matter.
I took a look at the controls valving and I can not see how to take it apart other than removing the hoses and the end caps on the left side.
I did not look on the underside yet but that may be the next step.
I also discovered that the bucket does slowly curl and leak down.
I noticed a squealing that I originally thought was the water pump or belt but on closer inspection it is coming from the Loaders Aux Hydraulic pump.
Also I confirmed that the hydraulic pump shaft IS turning.
I removed the spin on filter which is on the Hydraulic return line and dumped it. looks perfectly clean.
If I can figure out how to take the valve apart I may get this solved.
/ Yanmar 240 Loader Hydraulic issue #24
Looks similiar to the Dukes 1225 valve. Can you see a model number on it? Lever end and oppisite end is where it will come apart.
I can't see the model number, it may be painted over, but it looks identical in every respect to the Dukes web page spec for the 1225.
You saved me a load of time identifying that unit so many thanks for your response.
Once I relieve the system Hydraulic pressure and remove the springs, levers etc should I just be able to pull the entire valve spool out the front (or back)?
/ Yanmar 240 Loader Hydraulic issue #28
Squealing may be a sign of running against relief..
/ Yanmar 240 Loader Hydraulic issue #29
I don't know why you can't loosen the line that controls the lift / lower part of the loader ..If you do this, the loader will have to fall..There is something in your valve circuit not letting the fluid to move ,so the loader can fall
I will take the stuff off at the spring end #18 and pull it out towards the front lever, after I loosen the hyd hose to relieve pressure in the lines.
The squealing is occurring at the pump so perhaps it has a pressure relief that is going off due to the valve port being blocked?
/ Yanmar 240 Loader Hydraulic issue #31
yes that what he is saying the squealing is cause there is strain. the strain is due to the fluid not being able to go through the valve corectly for some reason so its running against the releife.
I pulled the valve shuttle out of the valve control block, started the tractor and let some fluid gush out to verify that there was fluid reaching that point and to flush any debris.
Then I put the shuttle back in and still no luck.
Then I took the filter off which is down stream of the control valve block and started the tractor and confirmed fluid was gushing out.
Then carefully I loosened the hose connection the goes from the hydraulic pump to the IN port of the valves. I was expecting 2500 psi there but when the spray started it seemed rather weak, more like garden hose pressure.
I'm thinking the Hydraulic pump is not developing the high pressure I was expecting.
I think my next move is to take the Hydraulic pump off and open it up to see whats the matter.
Considering how sudden the hydraulic just went out, I'm hoping its something simple like the key sheared off and perhaps the squealing when moving the levers is the shaft slipping.
I got to the engine coupling which is a dual row bicycle chain style coupling and wonder how to remove it or otherwise detach the pump.
Any ideas on how it might be attached and the best way to remove it?
/ Yanmar 240 Loader Hydraulic issue #34
i've said that.. apparently the op doesn't want to...
/ Yanmar 240 Loader Hydraulic issue #35
I can't remember if he said if his 3 pt is working or not.. The way I see it... If the 3 pt is raising and lowering.. He has no pump problems
While I had the control shuttle out I should have tried to lower the bucket as it is supported so as not to fall. Perhaps the pressure can be released. I forgot to try it.
Now that I know how easy it is to remove the valve shuttle I can try this evening and see what happens. I'll stand clear and be wearing goggles in case there's some squirting.
/ Yanmar 240 Loader Hydraulic issue #37
in the end, with the machine off, he could simply remove the return hose from the valve and move the spool that goes to the boom to the dump position and the bucket should come down and oil should exhaust.
if it don't.. it's either in the valve.. or it's a mechanical problem in the bucket linkage.. or something balled up inthe cyl binding it.
IE. t's mechanical or it's fluid. and it's in or before the valve.
This could have been diagnosed in 15 minutes with a wrench sized for the hose fittings and a bucket. ( OR LESS TIME if you didn't mind an oil leak! )
the fact that it has taken 37 posts to NOT YET KNOW why the bucket won't lower is a shame...
/ Yanmar 240 Loader Hydraulic issue #38
Well, look at it this way... There are those of us that can, and there are those of that can't.. We're to try to help those that can't
/ Yanmar 240 Loader Hydraulic issue #39
Two thoughts...like the other guys if the bucket is not coming down that has nothing to do with the pump. something is holding pressure in there. The fast that you had fluid puming out is good but irrelevent to the loader not coming down really. And the 2500psi is cause its contained, just pumping out of a hose it only pumps like 5gpm right? not like it will shoot 200 feet or anything...but i am no expert just thinking out load here...a garden hose pumps something like 5 gallons a minute right?
And the other though...did i read that you have an auxillary pump for the loader..."conected with a double row bike chain" if this is the case the pump on the tractor could still work and he could have 3pt power but no power on the aux pump if it was sheared. My thoughs on the chain is you need a breaker to break the link in the chiain if there is no provision to slack it up.
Yes its an aux pump on the front of the engine power takeoff just for the FEL. Not plumbed into the stock system so the 3pt is uneffected and working fine.
My logic tells me that if I or anyone else would start their tractor and start to remove the Pressure line that goes into the IN of the Valve block while running, there would be a contained pressure of ~2500 psi and as you loosen the hose fitting a high pressure spray would be emitted. My test as such showed a weak stream probably more like a garden hose pressure leak.
Sorry this is all taking so long but I don't get time to work on the tractor much, but do appreciate all the advice as tractors/hydraulics are new to me.
Starting to take off hoses were my next idea as suggested.
I am somewhat perplexed about removing hoses and the twisting up they may get, or are the threads at both ends in opposite directions so you have to tighten/loosen both ends at the same time and hence
there is not a lot of twisting.
I think I better add some pictures to help clarify my issue
Great Plains Ultra Till 3030 (A63688)
Great Plains Ultra...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
2014 Nissan Murano Cross Cabriolet AWD SUV (A61574)
2014 Nissan Murano...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
