Yanmar 187
/ Yanmar 187 #1
Ldavidgrover
Florida
MF 30B
Looking for a used repair manual for a Ym 187 or silimar with the 18hp diesel. I was brush hogging today and I just cant take the smoke/ oil coming out of the breather hose anymore. Better try to fix it now before I have more problems
/ Yanmar 187 #2
You realize this is cause your rings are worn out and you will need to at minimum replace the rings. But some sort of rebuild is instore here.
/ Yanmar 187
Yea I know, Just keep pushing the little machine one day at a time. She's ready to quit. I was just looking for torque spec, tear down and install. On a positive note there are little or none at all little mosquitoes flying around with all the smoke...lol
/ Yanmar 187 #4
Oh ok. Someone will post the specs. I know Winston posted the specs on a different model on the thread about a 1610 or whatever locking up.
/ Yanmar 187 #5
Ldavid, I have the original service manual for the 186 I think is very similar to the 187, If needed I could scan and email a few pages, but it would take me a month to scan the whole manual. Just let me know exactly what pages, and when you will need them. I am on this site almost every day.
Removing and scanning the whole motor section, would just take to much of my time, as I have a bunch of xmas presents still to make here in the shop.
/ Yanmar 187
Thanks Pete. Looking for head bolt spec, rod bolt, oil pan , valve cover torque spec. Maybe since I have a birthday coming i should invest in a manual.
/ Yanmar 187 #7
I will try posting here, pdf of head instal, but message me with your email, so can send direct.
  • 186 head install.pdf
/ Yanmar 187 #9
These are the piston and rod pages.
  • piston_rod_1.pdf
  • piston_rod_3.pdf
  • piston_rod_4.pdf
  • piston_rod_5.pdf
/ Yanmar 187 #10
Nothing in the manual, on oil pan or valve cover, I think you are on your own there.
good luck, pete
I posted the full pdf's here, in case someone else needs them, and does a search instead of emailing them to you. If you need more, post.
/ Yanmar 187
Ok pete I've finally got into the tear down. The only problem or really I just ran out of day light. But I'm trying to remove the injector pump and it seem like it being held by something. What's the trick? Dave
/ Yanmar 187 #14
be careful! i think thats the governor rack, apparently they are very fragile. some springs and the like have to be removed before it will come out. PS i have never pulled one out either:D
/ Yanmar 187 #15
Haven't removed one either but I believe the rack has to be slid all the way one way, not sure which way, to allow it to come out.
/ Yanmar 187 #18
yes theres a trick; I read about this somewhere; google "yanmar injector pump removal"; It took days of fiddling (sorry) for the guy to get the trick in an engine overhaul; i recall it had something to do with the govenor mechanism / linkage; post it when you get the pump off; preferably with a couple of pics; the challenge will be to not rewin the camera with grease/diesel in the process ;).
Iv got a ym 180d 3 cyl 18 hp 1989 that Im looking for a service manual for too:) ... I have a manual shift; I think the 186 was a power shift; very similar otherwise; Im trouble shooting electrical issues at the moment and the owners manual is too general to pinpoint the problem.
/ Yanmar 187
Ok Guys its been months now I have finally got the motivation I need to continue on the tractor. I found the problem. The number 1 cylinder had a broken ring. So I ordered all the parts for a rebuild and should be up and running this next weekend. keep you posted.
Miva VA13 (A64912)
Miva VA13 (A64912)
CAT R500/D9R Ripper Teeth (8) (A68134)
CAT R500/D9R...
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
FIXED FIFTH WHEEL ATTACHMENT (A68842)
FIXED FIFTH WHEEL...
2012 LS G3038H (A64911)
2012 LS G3038H...
MACK SINGLE AXLE(INOPERABLE) (A67714)
MACK SINGLE...
