Yanmar 1500D Green
/ Yanmar 1500D Green #21
Thanks Relhogh. I think I had it on the edge of it.
Well I did enough damage for today. I loosened the left side cover hoping it would come off.
NO LUCK. I also took off the PTO and I can see the bolts in the end of the axle but thru the two inch whole I don't see getting a wrench on it. I know I could never get it back in.
You mentioned a plate in the bottom but the only bolts are for the pin hitch.
I noticed you had yours removed.
There has got to be someone who had brake problems on a Green
Have a nice evening Y'all
/ Yanmar 1500D Green #23
Might have to reconsider removing the hydraulic lift assembly on top.
/ Yanmar 1500D Green #24
Relhogh, how is your pin hitch attached? Is it on a flat plate? I'll take a picture of mine. Tell me if it's the same. I had a heck of a time getting the axle housing off. There were alignment pins and 30 yo gaskets holding it all together.
/ Yanmar 1500D Green #25
Best picture I can get right now. The plate the hitch is on is the plate that seals the axle housing.
Yeah Winston1, I guess your right.
"d" I think mine is quite similar but hard to use for access.
I took the day off. Dog to vet, me to doctor and me to physical therapy.
Back at it tomorrow.
Hey (D) I am a lazy typist.
Sorry but I couldn't post a reply yesterday.
I took the 8 nuts and bolts off the pin hitch and beat on it.
No luck. Then I noticed somone had welded it on.
Winston 1
I took the hydralic lift off and got a great view of the bolt. Not great access but a great view.
I was able to get a wrench on it thru the pto hole and used a large pipe wrench on the axle and about 40 turns later the bolt came out.I was then able to pry the cover off. The large gear stayed pretty much in place. I can't wait to see what a hassle getting the bolt back in.
By the way the brakes are gone, they were covered in rust.
I was looking a getting some brake material and gluing & riveting it on.
I will send pictures later.
Thanks to you guys for your help.
/ Yanmar 1500D Green #30
For future reference, there should be two threaded holes in the housing which aren't used. These are meant to thread the bolts you just removed into. These holes are through holes which allow the bolt to push the cover away from the tractor. Makes easy work of the separation.
Sent from my SCH-I500 using TractorByNet
Domush,
I appreciate the post but I am not sure what bolts your refurring too?
I will look at your restoration project today.
/ Yanmar 1500D Green #33
relhogh said:
Domush,
The bolts you remove from the housing itself. You just re-insert a couple of them back into those threaded holes and "tighten" them (although you are really just screwing them through the housing, as there is nothing to tighten them against). As you screw them in, the bolts go through the housing and push off the transmission, thereby separating the two. After that, you just scrape off the gasket and pull it off.
I used a strap to support the housing and simply pivoted it aside, that way I wouldn't have to lift it back in place. Was much easier that way.
Domush,
I am not removing the differential case. just the axles and brakes.
are we on the same page?
/ Yanmar 1500D Green #35
relhogh said:
Domush,
when I said transmission, I meant differential, sorry.
The housing I speak of is that big plate looking thing through which the axle protrudes and has about six or eight bolts. If you wish to remove the axle, that housing must go with it.
Domush
I got the axle and brakes (one piece)Greenoff.
I still don't understand the bolt thing?
Is this possilble on a Green 1500?
Winston 1
Sorry I missed your reply.
The bolts and studs were OK.
Maybe some extra help needed.
Do you think the kit will fit my Green?
/ Yanmar 1500D Green #38
Winston 1
The kit is listed under the red and green but Hoye could answer that question. Does your brakes look like what you see in the kit?
Interesting the plate was welded on. Is it welded solid all the way around or just in spots? Asking thinking if it is just spot welded you might grind the welds off to remove it. By now I'm thinking you know what kind of access it would allow to get to the gear bolts. Might not be worth it. Just thinking outloud.
Winston 1
It is welded solid along both sides. I don't know the reason ,maybe water?
I think I could have gotton to the bolts from under there but I will never know.
Domush
I looked at your restore.
I don't know if I would have the patience to take on that size project.
Looking good:thumbsup:
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
SHOP BUILT  PRESSURE WASHER TRAILER (A67714)
SHOP BUILT...
2012 International Maxxforce (A64911)
2012 International...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2019 Polaris Ranger Crew XP1000 4x4 Gas Utility Cart (A64557)
2019 Polaris...
