XR3135 regeneration time?
   / XR3135 regeneration time? #21
My first regeneration was at 18h. But I was using the tractor on the higher gear I could to keep the rpm low. I realized then that it is not a good practice.
Next regens happen at 75h and 128h. I keep the rpm mostly at 1600rpm, now. Regen lasts a few minutes rpms go up a bit and are fluctuating. I just ignore it and continue my work. It does smells weird though!
A rise in the Regen interval is certainly encouraging. I was just a little surprised that my first one was at 24 hours. Getting very antsy for Spring to arrive so I can work it!
   / XR3135 regeneration time? #22
I have an older model XR3037HC with the Shibaura engine which has 5 hr. regen cycles instead of 50 hr on the newer 3100/4100 series with LS engine. Rarely do I notice it is in a regen cycle but it always seems to be regenerating when I'm finished using it and ready to park. After 4 years I still haven't learned to check the dash before I'm done work so I can hit the regen postpone button. Seems senseless to let it run for 20-30 minutes to complete a cycle. Rather have it regen while working.
IMO good quality fuel and keeping the RPM's up help extend the time between cycles.
Most of the time I run at 2200 or higher RPM.
   / XR3135 regeneration time? #23
Good info.
   / XR3135 regeneration time? #24
I'm almost to 800 hrs on my XR3037HC and don't even pay attention to the DEF cycle anymore. It comes on when it comes on and off, the same.
It happens, when it happens.
It's also a given that I do NO hay production and can't ever remember being in a situation when the cycle would've presented a fire hazard here in Florida.
You'll notice when it doesn't regen for electrical reasons, as has occurred on this machine. You'll experience a "Limp Mode" scenario. Also, there'll be an odd odor. Which is about the best I can describe, from the engine exhaust. The DEF screen is blocked and can't/won't regen for whatever reason.
   / XR3135 regeneration time? #25
XR3135H. Here is some regen data. I get nowhere near 50hrs but I'm probably not loading it very hard. Have a lot of PTO and ground work to do this spring, so I'll see what I get then.
The short regen time does not affect me at all. Posting here for interest.
Hourmeter - Hrs between regen's
16 16
22 6
28 6
44 16
60 16
76 16
96 20
112 16
   / XR3135 regeneration time? #26
16 16
22 6
28 6
44 16
60 16
76 16
96 20
112 16
It will be interesting to see regen times while running at PTO speeds.
   / XR3135 regeneration time? #27
I'm not hopeful. I usually operate around 2000 rpm, but my run times have not been very long lately.
However, I made her bark pretty good running a 74" snowblower this weekend. that was fun.
   / XR3135 regeneration time? #28
I think mine went off at 38 hrs. I'm at 57 hrs now and havent had a 2nd one yet.
Primarily using it for rotary cutting and clearing brush on my property. Will be leveling some dirt in the spring, too. I tend to run it at 2000-2200 RPM when working , and a bit above idle when moving without any load.
Dealer said this was good practice.
D
   / XR3135 regeneration time? #30
The last video had me laughing at the irony of how they fixed the man's tractor. If it were me, I'd keep it, and tell LS I'm happy with no computerized tractor.
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
2005 JOHN DEERE 310SG BACKHOE (A60429)
2005 JOHN DEERE...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
John Deere S350 (A60462)
John Deere S350...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
