XR3135 regeneration time?
   / XR3135 regeneration time? #11
3Lfarms, I can live with that. Other posts had me worried, talking about loss of power and frequency of regen. Some stated it felt like "Limp Mode" when in regen.
   / XR3135 regeneration time? #12
XR3135H. First Regen today@ 24hours. Duration of regeneration was 20 minutes. I was on the backhoe digging up stumps and the engine was running 2200rpm. The engine pitch changed slightly and the exhaust smelled funny. I was finished for the day so I parked it and idled it down (now @1100rpm). When regeneration was complete the regeneration lights on the dash went out and the idle speed dropped to 800rpm. Done Deal! IMG_20170821_191533.jpgIMG_20171009_150226_hdr.jpgIMG_20171009_150203_hdr.jpg
New Box Blade and a couple of Stump shots. Love It!
   / XR3135 regeneration time? #13
XR3135H. First Regen today@ 24hours. Duration of regeneration was 20 minutes. I was on the backhoe digging up stumps and the engine was running 2200rpm. The engine pitch changed slightly and the exhaust smelled funny. I was finished for the day so I parked it and idled it down (now @1100rpm). When regeneration was complete the regeneration lights on the dash went out and the idle speed dropped to 800rpm. Done Deal!View attachment 524208View attachment 524212View attachment 524213
If you keep your RPM's up, keeps the heat up and it will cut the regen time in half.
   / XR3135 regeneration time? #14
cford36, Regen was almost complete when I idled it down. I mainly wanted to see what the actual rpm increase was during a Regan cycle. I thought it would have been more than 300 rpm. Good advise though, thanks.
   / XR3135 regeneration time? #15
XR4155 here, first regen at 50 hours during first service (I wasn't present) and second at 100 hours. Working my way up to the 150 hour mark, so I'm guessing I'll see another regen soon with a ~50 hour cadence. I was hauling rock and didn't seem to notice any power loss, though it did jump up some RPM like others had mentioned.
   / XR3135 regeneration time? #16
I have 100 hrs on the 3135 and have kept track of every regen. It is slowly increasing in intervals, but I don't think I have hit 30 hrs. I'll check my records. As already stated, usually I notice the smell before the light on the console. No real issue with regen for me.
   / XR3135 regeneration time? #17
Both mine have been at about 40 hours. I think it depends upon how hard your are working it. Higher RPM and the harder you work it, the more time between. The more idling the more regens.
   / XR3135 regeneration time? #18
I was surprised mine waited until 48 hours before it’s first regen. It pretty much idled or fast idled most of the first 20 hours moving some things around and test fitting attachments. I always think it’s only going to take me a couple minutes to hook up, so I leave it running. 30 minutes later I’m finally ready to do some actual work. Lol
   / XR3135 regeneration time? #19
I was very surprised when my first regen was at just 24 hours. 90% of those hours were at 2200 or so RPM using the backhoe or fel. 10% at idle while putzing around or warming up.
Very hard getting used to keeping the RPM up when not working the tractor. It will be interesting to see when the next regen will occur.
   / XR3135 regeneration time? #20
My first regeneration was at 18h. But I was using the tractor on the higher gear I could to keep the rpm low. I realized then that it is not a good practice.
Next regens happen at 75h and 128h. I keep the rpm mostly at 1600rpm, now. Regen lasts a few minutes rpms go up a bit and are fluctuating. I just ignore it and continue my work. It does smells weird though!
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2003 PETERBUILT PB330 DUMP TRUCK (A60430)
2003 PETERBUILT...
CATERPILLAR 255 SKID STEER (A60429)
CATERPILLAR 255...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
