Xj2025 single bottom plow
/ Xj2025 single bottom plow #1
dwalk19
Addison, ny
2018 LS XG3140H TLB
Any XJ owners out there tried pulling a single bottom plow with there machine, i'm curious as to how well it would do, my soil is pretty rocky and definetly has clay, thanks
/ Xj2025 single bottom plow #2
LS/XJ2025H is 1,609 pounds, bare tractor, with 24.4-horsepower/18-horsepower PTO and 4-WD.
In MOIST rocky/clay soil you can pull a 12" or 14" size single moldboard plow easily.
Full size moldboard plows will not fit your subcompact tractor, despite Category 1 Three Point Hitch. You will need a moldboard plow specifically designed to fit subcompact tractors.
VIDEO: subcompact tractor plowing - YouTube
Alright thanks,good to know, i do have filled tires also, now to start looking for a good used plow for spring, thank you
/ Xj2025 single bottom plow #4
Alright thanks. i have filled tires. Now to start looking for a good used plow for Spring.
Now is the time to plow.
Late Fall / early Winter is the best time to plow. Alternate freeze/thaw cycles will break up the clay in your plowed ground.
Used implements are cheapest when there is snow on the ground.
/ Xj2025 single bottom plow #5
Sounds good, thanks for all the input
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A64280)
2006 FORD F-450...
2013 Ford F-150 Crew Cab Pickup Truck (A61573)
2013 Ford F-150...
2014 International 4300 Single Axle Dump Truck (A62613)
2014 International...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
UNUSED WOLVERINE 7' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
