Xj2025 single bottom plow
/ Xj2025 single bottom plow #1
dwalk19
Gold Member
Addison, ny
2018 LS XG3140H TLB
Any XJ owners out there tried pulling a single bottom plow with there machine, i'm curious as to how well it would do, my soil is pretty rocky and definetly has clay, thanks
/ Xj2025 single bottom plow #2
LS/XJ2025H is 1,609 pounds, bare tractor, with 24.4-horsepower/18-horsepower PTO and 4-WD.
In MOIST rocky/clay soil you can pull a 12" or 14" size single moldboard plow easily.
Full size moldboard plows will not fit your subcompact tractor, despite Category 1 Three Point Hitch. You will need a moldboard plow specifically designed to fit subcompact tractors.
VIDEO: subcompact tractor plowing - YouTube
Alright thanks,good to know, i do have filled tires also, now to start looking for a good used plow for spring, thank you
/ Xj2025 single bottom plow #4
Alright thanks. i have filled tires. Now to start looking for a good used plow for Spring.
Now is the time to plow.
Late Fall / early Winter is the best time to plow. Alternate freeze/thaw cycles will break up the clay in your plowed ground.
Used implements are cheapest when there is snow on the ground.
/ Xj2025 single bottom plow #5
Sounds good, thanks for all the input
UNUSED WOLVERINE HYD SICKLE BAR MOWER (A64281)
UNUSED WOLVERINE...
SIDE STEPS FOR 2009 TAHOE (A64281)
SIDE STEPS FOR...
3pt 20' Cultivator (A64119)
3pt 20' Cultivator...
Reynolds 18CR (A64119)
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
ROLLS OF CHAIN LINK FENCE (A64281)
ROLLS OF CHAIN...
