Xj2025 single bottom plow
/ Xj2025 single bottom plow #1
dwalk19
Addison, ny
2018 LS XG3140H TLB
Any XJ owners out there tried pulling a single bottom plow with there machine, i'm curious as to how well it would do, my soil is pretty rocky and definetly has clay, thanks
/ Xj2025 single bottom plow #2
LS/XJ2025H is 1,609 pounds, bare tractor, with 24.4-horsepower/18-horsepower PTO and 4-WD.
In MOIST rocky/clay soil you can pull a 12" or 14" size single moldboard plow easily.
Full size moldboard plows will not fit your subcompact tractor, despite Category 1 Three Point Hitch. You will need a moldboard plow specifically designed to fit subcompact tractors.
VIDEO: subcompact tractor plowing - YouTube
Alright thanks,good to know, i do have filled tires also, now to start looking for a good used plow for spring, thank you
/ Xj2025 single bottom plow #4
Alright thanks. i have filled tires. Now to start looking for a good used plow for Spring.
Now is the time to plow.
Late Fall / early Winter is the best time to plow. Alternate freeze/thaw cycles will break up the clay in your plowed ground.
Used implements are cheapest when there is snow on the ground.
/ Xj2025 single bottom plow #5
Sounds good, thanks for all the input
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2022 John Deere 835M Gator (A63111)
2022 John Deere...
UNUSED ATSPOWER ELECTRIC WINCH (A64281)
UNUSED ATSPOWER...
2013 Ford F-350 Knapheide Service Truck (A61573)
2013 Ford F-350...
2025 78in. Hydraulic Dual Cylinder Rock Grapple Skid Steer Attachment (A61572)
2025 78in...
Crustbuster 6020 TW36X6 (A64119)
Crustbuster 6020...
