Xj2025 single bottom plow
/ Xj2025 single bottom plow #1
dwalk19
Addison, ny
2018 LS XG3140H TLB
Any XJ owners out there tried pulling a single bottom plow with there machine, i'm curious as to how well it would do, my soil is pretty rocky and definetly has clay, thanks
/ Xj2025 single bottom plow #2
LS/XJ2025H is 1,609 pounds, bare tractor, with 24.4-horsepower/18-horsepower PTO and 4-WD.
In MOIST rocky/clay soil you can pull a 12" or 14" size single moldboard plow easily.
Full size moldboard plows will not fit your subcompact tractor, despite Category 1 Three Point Hitch. You will need a moldboard plow specifically designed to fit subcompact tractors.
VIDEO: subcompact tractor plowing - YouTube
Alright thanks,good to know, i do have filled tires also, now to start looking for a good used plow for spring, thank you
/ Xj2025 single bottom plow #4
Alright thanks. i have filled tires. Now to start looking for a good used plow for Spring.
Now is the time to plow.
Late Fall / early Winter is the best time to plow. Alternate freeze/thaw cycles will break up the clay in your plowed ground.
Used implements are cheapest when there is snow on the ground.
/ Xj2025 single bottom plow #5
Sounds good, thanks for all the input
