XC drag build
/ XC drag build #101
Like carbide wear bars on snowmobile skis?
/ XC drag build
I'm taking Wednesday, Thursday and Friday off and work on this project. Boss says i don't do much anyway. 🤣
/ XC drag build
I was suppose to be at the school shop this am but high winds cause school to be canceled but I will get in to do work shortly. Here is a print and pic of skags on implements. In the photo, the skag is below the frame at the bottom right.
/ XC drag build #105
Kind of like a rudder
/ XC drag build
All parts made for two hitches and one was assembled yesterday. These are forged lift rings being welded on. Gosh those things are strong! All the square tubing you see is 2x2 with 3/16 walls. Any questions?
I should have took a pic of that 1/4 thick reinforcement plate before I welded it on. Can anyone guess why those 1" holes are punched in it?
A dog leg was added to it..
/ XC drag build #107
A place to store extra Hitch Pins? What are the rectangular "belt loops for"?
/ XC drag build
No, we do, as most XC groomers do, use a mini pintles so there is no pin. This is what they look like.
The belt loops are to run wires in for actuators on the implement. The holes you see in the hitch are for zip-tying the wires down. I can punch 1" holes as easy as 1/4 ones.
/ XC drag build
Here is a pic of me cutting out that 1/4 thick hitch reinforcement top plate. Its about 6" wide and 52" long. It was to wide for me to make a single cut, on the left and right sides.
/ XC drag build
I got lots done but it doesn't look like much. :rolleyes: The 2x2 angles with the holes on the front will hold the harrow teeth.
/ XC drag build #112
Using siderake/harrow teeth to loosen the moguls is brilliant!
/ XC drag build
Now the smaller, secondary frame is being added that will have tooth cutting bars inside it. The angles seen on the floor will hold the hardned steel flats with teeth and some diagonal supports for them.
/ XC drag build
I should have added (slow thinker :)) If I get the plastic mounted onto it and the hallow frame painted, I could test it out next week. I'd need some system to lift or hold the frame up for turnaround locations, or if there is a problem with it. What do you think?
/ XC drag build
More pics I found in my camera. This is the frames and how they fit in together.
.250 inche plate will be attached in-between them. Plastic wear sheets will be mounted on the frames to go against this plate.
Frames being welded. The primed tabs be attached are 3/8 thick. Any questions?
/ XC drag build
I'm kind of surpized no one has asked why the holes drilled for the harrow teeth, there spacing looks so goofy?
/ XC drag build #117
Too much Christmas Cheer?🍸
/ XC drag build #120
It's coming along nicely. It most certainly doen't look like the run of the mill groomer to pull behind the regular snow machine. Pulling that loaded with snow would be way to hard on my snowmoble but a quad on tracks would have no issues,
2018 Chevrolet Silverado1500 Crew Cab Pickup Truck (A61573)
2018 Chevrolet...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
429860 (A61166)
429860 (A61166)
2025 Swict 72in Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
