X700 series hydraulics.
   / X700 series hydraulics. #21
A 3 in cyl with 1.5 bore and 945 psi has a push force of 6,680 lbs.
   / X700 series hydraulics. #22
Yes. But that is when the load is truly perpendicular to the cylinder. On just about every trailer, you get less than half the potential lift. Easy enough to calculate if you have the geometry. Still, even at say 25%, there is enough lift in most cases. My hydraulic trailer sometimes needs "help" getting it started if the load weigh is to fall forward of the piston. So, I try to load only the back 2/3rds. This is with a 1000 PSI JD425. I haven't tried it with my 2700 PSI Kioti. Suspect that would be no problem at all. Anyway, if I could get more vertical angle, I'd have a lot more power. That is why I suggested inquiring about raising the bed/pivot point. Then the cylinder could be more vertical.
   / X700 series hydraulics. #23
3 in cyl, 1.5 in shaft, and 945 psi.
Even at 45 degrees, the cyl will push 4,723 lbs.
---------25------------------------------2,823 lbs
---------10------------------------------1,160 lbs
   / X700 series hydraulics. #24
Good. Someone paid attention to vector math in school.:thumbsup:
   / X700 series hydraulics. #25
Trig. Sin(10)=0.1736 X 6680 = 1159.65.
   / X700 series hydraulics. #26
10 degrees probably isn't that far off, at least at initial lift.
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
2017 Nissan Rogue SUV (A59231)
2017 Nissan Rogue...
2020 CATERPILLAR 323 EXCAVATOR (A60429)
2020 CATERPILLAR...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
