X700 series hydraulics.
/ X700 series hydraulics. #21
A 3 in cyl with 1.5 bore and 945 psi has a push force of 6,680 lbs.
/ X700 series hydraulics. #22
Yes. But that is when the load is truly perpendicular to the cylinder. On just about every trailer, you get less than half the potential lift. Easy enough to calculate if you have the geometry. Still, even at say 25%, there is enough lift in most cases. My hydraulic trailer sometimes needs "help" getting it started if the load weigh is to fall forward of the piston. So, I try to load only the back 2/3rds. This is with a 1000 PSI JD425. I haven't tried it with my 2700 PSI Kioti. Suspect that would be no problem at all. Anyway, if I could get more vertical angle, I'd have a lot more power. That is why I suggested inquiring about raising the bed/pivot point. Then the cylinder could be more vertical.
/ X700 series hydraulics. #23
3 in cyl, 1.5 in shaft, and 945 psi.
Even at 45 degrees, the cyl will push 4,723 lbs.
---------25------------------------------2,823 lbs
---------10------------------------------1,160 lbs
/ X700 series hydraulics. #24
Good. Someone paid attention to vector math in school.:thumbsup:
/ X700 series hydraulics. #25
Trig. Sin(10)=0.1736 X 6680 = 1159.65.
/ X700 series hydraulics. #26
10 degrees probably isn't that far off, at least at initial lift.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64277)
KNOW BEFORE YOU...
Vandale Feed Wagon (A65640)
Vandale Feed Wagon...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
2007 International 8600 Parts Truck (A63689)
2007 International...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
