Would you use this pic in an advertisement?
   / Would you use this pic in an advertisement? #1
square1
Michigan
Ford 1700 4x4 w/ FEL
Would you buy this based on this pic?
   / Would you use this pic in an advertisement? #2
I would probably also consider the price and reviews, if any.
   / Would you use this pic in an advertisement? #4
Depending on price.
I'm not sure I'd store a chain on that hook, let alone hook something to, or pull something by a chain attached to that hook.
   / Would you use this pic in an advertisement? #6
Not a welder... What is it about that hook (other than the company) that's not good?
I got my hooks several years ago from Ken's Bolt On Hooks, and they are top quality. I highly recommend them.
   / Would you use this pic in an advertisement? #7
Inconsistent bead size, substantial crater at the lower end of the weld, insufficient throat depth also at bottom. Will it break, maybe not, would I put my name on it...nope.
   / Would you use this pic in an advertisement? #10
So it got galvanized after the weld?
It does look like he ran out of stick or stopped the weld right there for some reason, wouldn’t have used that side but it’s not like the average photographer would figure that out.
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
