Worth modifying or will it fit
/ Worth modifying or will it fit #1
YesDeere
Merland
54" snow plow w/ all attachments for a johndeere 4100 came a tractor w/149hrs Asking $800 OBO
This is a cl ad. I have a 4310.
Doing this from my phone. Will try and paste pics. I know it's a smaller tractor but if had the blade and hydraulics it may be worth the fab. If needed I think the blade could be made wider. Let me know what you think.
After getting home and getting on jd parts I see it is way different. Has anyone bought a plow for a 4310? $$$$???
/ Worth modifying or will it fit #3
Depending on how much snow you have to plow, and how long your driveway is; you might contact your local Deere dealer and price one of the QA plows for your loader (I'm assuming you have a 420, 430 or newer loader).
The 72" manual angle QA plow retails for about $1200. The hydraulic angle model is about $500 more.
Unless you're in western MD (Garrett County or close), you won't normally see that much snow at one time...normally.
Thanks Roy.
I thought about that but my loader is already a bit abused and loose. I was thinking of the plow that uses a cradle on the frame. I have a feeling it's going to be a bad winter. I have a fairly long driveway and several neighbors I would like to help.
/ Worth modifying or will it fit #5
You wont be happy with that blade anyway. For the money, a rear blade is hard to beat (bang for buck) when it comes to light snow removal in our area.
/ Worth modifying or will it fit #6
That blade is for the smaller frame tractors...I am tempted to lowball him since it's been for sale for a while-but I really don't need it.
/ Worth modifying or will it fit #7
Kenny;
Do you really think a snow blade is worth anything close to $800.00 ? I bought a 6 1/2' jeep plow for a hundred and modified the mount. Worked for several years. Sold it and built a loader. That works fine but recently found a used 59" JD front blower. Have to make a mount for the drive shaft but it should be the answer to the snow problem.
/ Worth modifying or will it fit #8
AB, yes it's worth $800 to some, a lot of guys can't fabricate or weld, and there are no used plows here for $100. That setup would be $1500 from JD if you bought it new.
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
iDrive TDS-2010H...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
International 154 Cub Lowboy, Gasoline, 60" Mower  (A62679)
International 154...
Cat CB24B (A60462)
Cat CB24B (A60462)
