Worth modifying or will it fit
/ Worth modifying or will it fit #1
YesDeere
Merland
54" snow plow w/ all attachments for a johndeere 4100 came a tractor w/149hrs Asking $800 OBO
This is a cl ad. I have a 4310.
Doing this from my phone. Will try and paste pics. I know it's a smaller tractor but if had the blade and hydraulics it may be worth the fab. If needed I think the blade could be made wider. Let me know what you think.
After getting home and getting on jd parts I see it is way different. Has anyone bought a plow for a 4310? $$$$???
/ Worth modifying or will it fit #3
Depending on how much snow you have to plow, and how long your driveway is; you might contact your local Deere dealer and price one of the QA plows for your loader (I'm assuming you have a 420, 430 or newer loader).
The 72" manual angle QA plow retails for about $1200. The hydraulic angle model is about $500 more.
Unless you're in western MD (Garrett County or close), you won't normally see that much snow at one time...normally.
Thanks Roy.
I thought about that but my loader is already a bit abused and loose. I was thinking of the plow that uses a cradle on the frame. I have a feeling it's going to be a bad winter. I have a fairly long driveway and several neighbors I would like to help.
/ Worth modifying or will it fit #5
You wont be happy with that blade anyway. For the money, a rear blade is hard to beat (bang for buck) when it comes to light snow removal in our area.
/ Worth modifying or will it fit #6
That blade is for the smaller frame tractors...I am tempted to lowball him since it's been for sale for a while-but I really don't need it.
/ Worth modifying or will it fit #7
Kenny;
Do you really think a snow blade is worth anything close to $800.00 ? I bought a 6 1/2' jeep plow for a hundred and modified the mount. Worked for several years. Sold it and built a loader. That works fine but recently found a used 59" JD front blower. Have to make a mount for the drive shaft but it should be the answer to the snow problem.
/ Worth modifying or will it fit #8
AB, yes it's worth $800 to some, a lot of guys can't fabricate or weld, and there are no used plows here for $100. That setup would be $1500 from JD if you bought it new.
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2020 Takeuchi TB250-2 Mini Excavator (A62613)
2020 Takeuchi...
2012 International (A59230)
2012 International...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
