OP
ultrarunner
Epic Contributor
- Joined
- Apr 6, 2004
- Messages
- 28,852
- Tractor
- Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
When I had a job that I did not like (for several different reasons), I just quit and moved to a different job or occupation. Worked until I was laid off at 74 years old, along with 15 others (most of which were "older"). Generally I liked what I was doing and where I was doing it or just moved on. Sometimes it was a "take this job and shove it". Sometimes it was I found a "better job". Sometimes it was straight commission....sometimes it was salary with bonus....sometimes it was time clock. I fit the job to my needs and went at it wholeheartedly.
Good Luck Ultra
Mike
Working to 74 sounds like you had a good handle on things... none of the men in my family have ever retired... worked until they dropped... the farming side it was more slowing down but still very much engaged.
If I had to be concise it would be Corp isn't following their own policies and procedures and the goal posts keep shifting... and reason is often no where to be found.
Not to get to far into the weeds...
A couple of months back the Fire Department was called... it was after my shift otherwise it would not have happened.
Policy is NO ONE enters a steril area unless dressed in Scrubs... no Street Clothes... makes perfect sense and the way it should be... 99.9% of the time.
But... the charge nurse stopped the Fire Department cold saying they could not enter with their Turn-Out gear and had to first go back to the staff locker rooms and change and their equipment would need to be wiped down first.
My thought is REALLY... and I heard about it from the Battalion Chief later...
We called 911 and Fire is Johnny on the spot and then told they have to change clothes first???
Either it is a 911 emergency or not... really made us look foolish... there I go again... saying "WE" and "Us" and was not even there.
