Work light on B2920?
/ Work light on B2920? #1
Vitster
Needville, TX
Kubota B2920
:confused2:Bought a large rectangular Blazer magnetic base Work Light at TSC for my B2920. I wanted it for mowing at night with my 60" MMM. I like to see the grass line on the right side real well when mowing, and the stock lights are too far out front. I tried it out hooking direct to battery to see how much light and WOW. Don't really need two of these for my needs. I plan to just use a marine cigarette lighter plug I'll mount in the black plastic fender assembly on right side so I can just stick the light onto the ROPS, plug in the cig. plug, and remove when not needed. I can also move it from one side of the ROPS to other and even shine it to the rear if needed. I'm electrically challenged and am trying to figure out the best way to run my wiring. This light is a 55W/H-3 bulb. Can I assume I have no issues using it with standard alternator on tractor at same time as stock lights? Is there a place under the seat where I can wire to, or is another way recommended? The tractor only has 11 hrs. on it and I haven't done much exploring yet. I wasn't really planning on using a switch. I do however plan to use a fuse, figuring 15 amp since that is the size fuse that came with my spotlight I use on my boat. Any recommendations, or pictures of where wires are on either a B2920, or a B2620, or even a B2320 which I presume would be the same. All help appreciated. Thanks. :confused2:
Just found some good information that was posted by KHNewman in Nov. of 2008 here on TractorByNet. I just typed in B2920.com and what was the first thing to pop up "Show me your rear work lights". I think he has answered some of my questions unless something has changed with the wiring since '08 on the B2920.
2022 EZ-GO ELITE...
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
2013 Mercedes Benz GLK SUV (A64557)
2013 Mercedes Benz...
Swict 60in Bucket Skid Steer Attachment (A64553)
Swict 60in Bucket...
2007 Ford Fusion Sedan (A64557)
2007 Ford Fusion...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
