woodmaxx flail mower?
/ woodmaxx flail mower? #242
I have had my 78" WM flail mower for almost a year now.
Tighten all the bolts when you get it and even better put a little blue loctitie on each one and lube every fitting.
I have broken several of the cutting "Y" blades andI ordered 3 today online from Woodmaxx.....$46. I need to find cheaper parts in the future with the way these break after hitting small saplings. Anyone have a source for better cheaper blades for these?????
/ woodmaxx flail mower? #243
May want to check out Flailmasters and see if you can match something up. I got my Alamo knives there and they are holding up GREAT. Have cut up a bunch of 1" saplings with no damage. Good luck
/ woodmaxx flail mower? #244
I will give them call next week, thank you
/ woodmaxx flail mower? #245
May want to check out Flailmasters and see if you can match something up. I got my Alamo knives there and they are holding up GREAT. Have cut up a much of 1" saplings with no damage. Good luck
That's where I got my Ford 917 knives & hardware from. Good prices & quality.
/ woodmaxx flail mower? #246
Which ones did you get: standard, heavy duty, or extreme duty? And how much were they, if you don't mind me asking. Their online catalog doesn't show prices.
/ woodmaxx flail mower? #247
I just found my old receipt for you:
EXTREME SERVICE BLADE M-105319M000000295 80 $104.00
These were for my Alamo flail and they seem to be holding up extremely well (no PUN intended)
Seemed like a good company to deal with as they were very helpful on the phone and got everything out quickly. When I need more blades I will order from them again.
I recall there website was not the best so I called them and it turned out to be a good idea as they made sure I got the right stuff the first time. Here is there info:
Call : (615) 848-1813
Fax : (615) 896-5652
Our Hours of Operation:
8:00am - 4:30pm CST
Flail-Master®
P.O. Box 1558
Murfreesboro, TN 37133
info@flailmaster.com
/ woodmaxx flail mower? #248
8:00am - 4:30pm CST
Flail-Masterョ
P.O. Box 1558
Great info ....thank you.
/ woodmaxx flail mower? #249
Your welcome - glad to help
/ woodmaxx flail mower? #250
Have a new Woodmaxx FM-96H with about 2.5 hours on it.
Agree with previous poster, check bolts frequently and use blue thread locker.
Had a rear roller wiper bolt with lock nut fall off after 30min of mowing and it was checked for tightness before leaving the shop.
A few other bolts with lock nuts have come loose as well, but i've been checking them every 15-20 min of operation and seem to have them all secure now.
PTO shaft shield on the mower vibrates and makes a lot of noise especially at the Far left shift position.
3pt top mount piece bolted to the mower different than the instructions showed, must have been a new design change for 2019 that didn't make it into the manual.
Overall its doing a nice job mowing 18-24" grass and weeds faster and nicer finish but seems to require more attention than the old 72" rotary cutter did.
John Deer MX8 Bush Hog, 3pt, Dual Gear Box, PTO (A62679)
John Deer MX8 Bush...
Kubota L175 Tractor (A62613)
Kubota L175...
2012 John Deere 135D Excavator (A65579)
2012 John Deere...
Four (4) TAG Excavator Couplers (A65640)
Four (4) TAG...
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
