woodmaxx flail mower?
/ woodmaxx flail mower? #242
I have had my 78" WM flail mower for almost a year now.
Tighten all the bolts when you get it and even better put a little blue loctitie on each one and lube every fitting.
I have broken several of the cutting "Y" blades andI ordered 3 today online from Woodmaxx.....$46. I need to find cheaper parts in the future with the way these break after hitting small saplings. Anyone have a source for better cheaper blades for these?????
/ woodmaxx flail mower? #243
May want to check out Flailmasters and see if you can match something up. I got my Alamo knives there and they are holding up GREAT. Have cut up a bunch of 1" saplings with no damage. Good luck
/ woodmaxx flail mower? #244
I will give them call next week, thank you
/ woodmaxx flail mower? #245
May want to check out Flailmasters and see if you can match something up. I got my Alamo knives there and they are holding up GREAT. Have cut up a much of 1" saplings with no damage. Good luck
That's where I got my Ford 917 knives & hardware from. Good prices & quality.
/ woodmaxx flail mower? #246
Which ones did you get: standard, heavy duty, or extreme duty? And how much were they, if you don't mind me asking. Their online catalog doesn't show prices.
/ woodmaxx flail mower? #247
I just found my old receipt for you:
EXTREME SERVICE BLADE M-105319M000000295 80 $104.00
These were for my Alamo flail and they seem to be holding up extremely well (no PUN intended)
Seemed like a good company to deal with as they were very helpful on the phone and got everything out quickly. When I need more blades I will order from them again.
I recall there website was not the best so I called them and it turned out to be a good idea as they made sure I got the right stuff the first time. Here is there info:
Call : (615) 848-1813
Fax : (615) 896-5652
Our Hours of Operation:
8:00am - 4:30pm CST
Flail-Master®
P.O. Box 1558
Murfreesboro, TN 37133
info@flailmaster.com
/ woodmaxx flail mower? #248
8:00am - 4:30pm CST
Flail-Masterョ
P.O. Box 1558
Great info ....thank you.
/ woodmaxx flail mower? #249
Your welcome - glad to help
/ woodmaxx flail mower? #250
Have a new Woodmaxx FM-96H with about 2.5 hours on it.
Agree with previous poster, check bolts frequently and use blue thread locker.
Had a rear roller wiper bolt with lock nut fall off after 30min of mowing and it was checked for tightness before leaving the shop.
A few other bolts with lock nuts have come loose as well, but i've been checking them every 15-20 min of operation and seem to have them all secure now.
PTO shaft shield on the mower vibrates and makes a lot of noise especially at the Far left shift position.
3pt top mount piece bolted to the mower different than the instructions showed, must have been a new design change for 2019 that didn't make it into the manual.
Overall its doing a nice job mowing 18-24" grass and weeds faster and nicer finish but seems to require more attention than the old 72" rotary cutter did.
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
2022 EZ-GO ELITE...
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
HONDA Plate Compactor (A64553)
HONDA Plate...
2022 Mac Trailers T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
1997 KENWORTH T300 4X2 S/A CAB & CHASSIS TRUCK (A67147)
1997 KENWORTH T300...
